Hi All
This is probably a no brainer to you clever people.
I have a number of grease galleries to drill some shafts 5.5mm Drill X 90mm deep
I need a example of some code do a drill retraction to clear the swarf
I can peak drill with a G74 down to Z-30.00 fine but how do i go deeper and clear the swarf with a retraction to Z0.50 and rapid back to hole bottom
With a G90 it rapids out fine but goes back into the hole at the programmed feed rate (takes ages)
I'm running a Fanuc 6T Lathe
Snow
