603,930 active members*
3,662 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Default Comms Program
Results 1 to 10 of 10
    Apr 2003
    1876
    Anyone know of a way to add custom communications programs to MC that can be set as default via Screen/Configure?
    'Rekd teh I didn't do it, I was sick that day!
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    May 2003
    6
    Corey teh hows it goin? Not as busy over here.
    Mcam forum member #1415
    Apr 2003
    1876
    Sup Corey. We'll liven it up
    I copied my app to the name/folder cimcodnc is in. Now if I can figure out what MCam uses to pass teh command to CimcoDNC, I can use that command in my proggie. Right now it opens it, but isn't sending the file data so it just closes again.
    'Rekd teh
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    May 2003
    84
    I use Cimco for our DNC and downloading. What exactly are you trying to do. Are you trying to set up one machine as the default? If so, I think it was in the DNC setup screen. I'll check when I get in today.
    Fish
    Apr 2003
    1876
    Fish, I'm trying to use a different program. One that I made. I want to drop it in place of the cimco one. I just don't know what instruction is sent from MC to Cimco to tell it what file to send, -s or /t or /send or -xmit or -xfer or somethgin.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    May 2003
    146
    rekd,
    I dont have your answer, but Ive been reading these posts here and "elsewhere". I applaud you for forging ahead on what I gave up on.
    Did you write the rs232 interface from scratch or did you find an active X component or something that already existed ?
    I wanted to take my access database to the next level and use it for downloading programs to the machines. I was looking for something turnkey.
    Care to divulge ?
    Dave teh "bowing down"
    Wee aim to please ... You aim to ... PLEASE.
    Apr 2003
    1876
    CAM, I made it from scratch. Right now it only sends, as I haven't had the need or time to finish the recieve portion yet. As for making one in Access, I'm not sure if you can use the MSComm control there, but I'll look into it. Even if not, you can call external programs and pass varialbes to them, which would allow it to work via a 3rd party program, like mine.
    'Rekd teh loopage
    Apr 2003
    1876
    CAM, I just tossed a Microsoft Communications control on my form for the setup sheets in Access, and sent a file to the port with it. (I didn't actually connect to a machine, but the port openend and data was sent.)
    If you want to discuss this further, email me or we can talk on LL later.
    'Rekd teh It said "Insert disk 3..." but only 2 fit.
    Mar 2003
    202
    REKD,
    You just need to goto screen, configure,start/exit then open theeditor options and pick other. It will open up the window you need toget your program to replace CIMCO. I hope this is what you needed.
    Apr 2003
    1876
    No, not the editor.
    The Communications.
    Choices: Mastercam or CimcoDNC.
    I want to use my own.
    'Rekd teh stingy
  1. Learning to Program CNC Turning Center
    By Farmer in forum G-Code Programing
    Last Post: 09-12-2005, 06:03 AM
  2. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  3. How to cut multiple parts (loop a program)
    By Bird_E in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2005, 09:16 PM
  4. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
  5. G-Code Cutter Comp Program
    By jcc3inc in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 05:29 PM
