587,133 active members*
3,217 visitors online*
    Jul 2003
    148
    Defining stock
    I had some blanks water jet cut to speed up the maching time. My question is, can I import the drawing of the part designed for water jet cut or is there an easy way to define the stock as having a hole in its center so I do not waste time cutting air? I tried using casting but I can not find mention of it in the help file. I'm use to mastercam and would just import a model of the stock.
    Jun 2006
    340
    You can import a model as the Workpiece that can be aligned, rotated, etc like the Part.
    Under the Model tab, select Workpiece and Import the model of your blanks.
    Feb 2012
    27
    One thing that could work is to extrude the curves on the part and use that as the workpiece.
    I often use this method when i work with parts that are watercut to profile and not starting from a square piece of stock.
    SprutCAM7 Waterline Roughing and Finishing Strategy - YouTube
  1. Defining stock shape
    By new2cnc in forum Mastercam
    Last Post: 10-11-2009, 03:35 AM
  2. Defining Tooling
    By deadeye_sd in forum Dolphin CAD/CAM
    Last Post: 02-21-2008, 02:27 PM
  3. Replies: 1
    Last Post: 11-03-2006, 07:21 PM
  4. A question about defining stock
    By RMagnusson in forum Mastercam
    Last Post: 02-27-2006, 04:59 PM
  5. Defining Stock Size In BobCADCAM
    By jonbanquer in forum BobCad-Cam
    Last Post: 01-26-2006, 01:58 AM
