603,935 active members*
2,909 visitors online*
Results 1 to 4 of 4
    Jan 2013
    16
    Delete G Code
    Surely it's on here, but I can't find it. I am trying to delete a line on my Fadal in fanuc G code.
    Possible?
    I can't get any response from DEL in the prompt.
    Thanks,
    Nov 2012
    96
    You have to type in the filename of each file you want to delete. They generally start with a capital "O", then hit the delete button.
    Edit. Oops, I misread. I wrote how to delete on a Fanuc.
    Jan 2013
    16
    How about to delete a line, or portion of line (ie single command)?
    Aug 2011
    2517
    on Fanuc cursor to the start of a line, press the EOB key then press the DELETE key and the line goes away.
    You could also try reading your Fadal manual......
