603,311 active members*
3,419 visitors online*
    Jan 2009
    4
    DeskCNC to HAAS controller
    I was wondering if anyone out would know how to set DeskCNC up to output G code for a HAAS SL20 lathe???? I have some model aircraft wheels and brakes that I drew up in 3D and want to convert the STL to G code so I can send the files to my brother to run on his lathe. Any help would be most appreciative.
    Chris
    Nov 2009
    105
    Greetings, I am new to DeskCNC. I am just using the CAM to create the G-code. I use a different controller software. I set the post processor to ISO G-Code-ABS ARC Centers on the Options - Misc TAB and then use SAVE Toolpath CNC function under FILE to create G-Code files generated from the Pocket and Contour function to cut parts. I only cut 2D projects from .dxf files.
  1. DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller
    By maycom in forum DeskCNC Controller Board
    Last Post: 06-02-2007, 07:33 PM
  2. Deskcnc users, what CAM software are you using with this controller?
    By Idle hands in forum DeskCNC Controller Board
    Last Post: 05-06-2006, 07:00 PM
  3. DeskCNC Controller and Xylotex
    By WarrenW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-30-2005, 07:06 PM
  4. DeskCNC Controller/driver
    By rogerbureau in forum DeskCNC Controller Board
    Last Post: 01-18-2005, 09:30 AM
  5. 2nd generation DeskCNC controller now shipping
    By imserv in forum News Announcements
    Last Post: 10-01-2004, 12:22 PM
