603,348 active members*
3,870 visitors online*
Thread: deskcnc info
Hybrid View
    Jun 2018
    deskcnc info
    Hello
    Please i need your help , about the Deskcnc 2end Generation controller board
    i woud like to upgrade my cnc router with a 6watts laser engraver that use TTL/PWM port .PLH3D-6W-XF Engraving Laser Head
    https://optlasers.com/plh3d/plh3d-6w-xf-laser-head
    i want to ask if his bord have a PWM output to drive this laser head.
    laser diode Control Inputs
    The laser head has two separate controls. Input #1 accepts 0 - 5V for analog power modulation. Input #2 accepts 0 - 24V for TTL/PWM and turns on the laser when the voltage exceeds 2.5V. (Input #1 can also be used for PWM if #2 is dedicated for TTL only.)
    Best regards.
    zouari Riadh
    Nov 2008
    18
    Re: deskcnc info
    The Deskcnc 2end Generation controller board does have a PWM output. This signal can be used to control Spindle RPM or Laser Power.
    There is a setting in the Options menu to choose between Laser and Spindle, as well as if PWM signal needs to be inverted.
    In your case, I would ting you want to go with #2.
