603,942 active members*
2,081 visitors online*
Results 1 to 13 of 13
    May 2025
    3
    DeskCNC and Sherline mini Lathe
    please I need help I had bought my Lathe from ImService and now they are shut down.
    I have the DeskCNC software with SYS-3A CNC SYSTEM 2nd generation Controller.
    Fred help me setup evrything with the lathe, and it worked great i used it for years
    making my pen/pencils. Istop using it fora few years now, and when I went to run
    the software to run my g-code it won't do nothing, can't jog or run any of my g-codes
    is there anyone I Houston or Bear Creek area that could come over and help me figure
    this out.
    Feb 2008
    37
    Re: DeskCNC and Sherline mini Lathe
    Quote Originally Posted by Glen66 View Post
    this out.
    make shure you have the right com port selected usually thats the problem.
    May 2025
    3
    yeah i did that but i run the software then go to mode then machine to bring up all the axis which is just 2 and then go to file and load my g-code its all ready to go so when i hit run/start/go ect. ect. nothing happens and it usually starts cutting but if i hit jog on one of the axis everything turns gray and you can't click on none of the axis or the start buttons in the program and i use to be able to do that before i stop using it but now it won't let me and I haven't change nothing in the software. i did delete it and reinstalled it went through and did the setup like me and Fred did so i know that's all correct dang thing got me confused as hell.
    Feb 2008
    37
    I had one of the old gen2 board fail on me before and it locked up . there is a small capacitor network bank on the board rc1 or rc2 that some how got shorted . Carl from deskcnc sent me a new board, just payed for shipping. just contact deskcnc
    May 2025
    3
    well can't do that Fred died a few years ago so IMservice shut down so I don't know who is updating the software and i don't know where they where getting the SYS-3A Controller and servo motors from
    well thanks for the help anyways i guess i will have to find a company that has servos and see what system they have and go with that
    Feb 2008
    37
    check with a multimeter all the input pins if it is shorted to ground, thats why there is a rc network in there to filter noise on input pins. that is how I found out it was the rc network falt. it would upload new firmware but locked up after that. you can order a new rc network from digikey or somewhere else. deskcnc has changed the rc network on newer boards by smaller ones. so far no problems.
    its me i just logged in on my original account finally got it back but any how so check those now i have three small boards one for x and one for z and there is one for the serial to usb port ok i have x and z has blue lights on steady but the serial is flickering fast could that be the problem
    i can take a video and show you if i need to
    I Was Born Without Gills, Therfore I Fish!
    Love The Wife, Fish Hard, Fish Till You Die!
    Feb 2008
    37
    the blue led on deskcnc board should blink fast when moving any axis. I only have the deskcnc board and rutex servos board not the fred´s system so I can not coment on how Fred´s servos works.
    https://youtu.be/3apPu6B-cX0
    ok this is just the controller turned on if you look close you will see the x and z not blinking
    and the serial is the one blinking really fast
    is there anyone Know's how to reset the board i think the serial port board needs to be reset i am not sure
    ok I don't need help on this no more found the problem and is fixed
    thanks for the help
    Apr 2004
    5951
    What was the problem, and how did you fix it? Resolutions in threads like this can be helpful when someone else has the same issue.
    Andrew Werby
    Website
    well it was a really stupid thing, ok i use deskcnc software that came with my lathe setup, in the software there is a setup
    for the lathe and mill and i have to reenter the numbers for the x and z axes and the choose the com port, Well Fred (RIP)
    help me setup everything and it worked great, but after it set awhile not using it i upgraded the software and reentered the
    setup, and thats where i had the problem. could not figure it out, until the other night when it snapped what Fred told me what i had to do
    when you bring up the machine in the software and then open one of your g-codes you hit go and it suppose to run or you hit x or z to jog
    suppose to move wouldn't do it. what i have o do is there is two buttons in the software thats pause and em stop i had to click on both
    buttons to open the em stop and take it of pause then everything worked great so i am back up and running so be sure you guys
    write down everything so i wrote that down in my notes so want have that problem again
  1. Imsrv Deskcnc sherline mill setup and lathe
    By xray965 in forum Mini Lathe
    Last Post: 07-30-2016, 02:47 PM
  2. sherline/deskcnc threading issue
    By erieworks in forum Mini Lathe
    Last Post: 06-02-2012, 01:01 AM
  3. Sherline or mini-mill spindle?
    By AK_Five-O in forum DIY CNC Router Table Machines
    Last Post: 01-24-2011, 01:34 PM
  4. Sherline Lathe/DeskCNC w/servo motors
    By Glen Hendricks in forum Mini Lathe
    Last Post: 10-04-2010, 10:50 PM
  5. Stepper Control for a Sherline Mini (real mini)
    By bill south in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2007, 05:04 AM
