I cant seem to get deskengrave to work. Anyone else have this problem? Here is a copy of gcode output of the word TEST I have tried it with two computers (Both under XP) and the same result.
you might want to take a look at parameter you are setting.
The best way to learn is trial error.
THE parameter which is giving you 0s is the decimal points.
By default it is set at 0 - so the multiple of 0 is all 0s
So you need to go in and write 2, 3, or whatever resolution you need and this should solve the 0 problem
Good luck
I am a novice too just put together my own small CNC from all the ideas from the net.
Ajay
