603,924 active members*
4,817 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > dial or test indicator for squaring/leveling linear rails?
Results 1 to 4 of 4
    Dec 2003
    128
    I'm looking for indicators on ebay for my diy cnc machine setup.
    What is going to be more useful for leveling rails? a test or dial indicator on the end of an arm attached to a magnetic base?
    both have their benefits , i would suggest a dial indicator , youll have more travel to play with
    Sep 2007
    217
    Depends on how accurate you need to be. Test indicators are usually smaller graduations where as Dial are not a fine and usually not jeweled where a test indicator will be.
    Aug 2004
    2849
    Well you have 2 problems....can you accurately move the dial indicator from one end of the rail to the other? You would be better off using a machinist level to level the rail and use a dial indicator at the end of a 3/8" drill rod to set the rail to rail distance at both ends of the rail. You can also use the machinist level resting on some accurate round stock to set one rail to the height of the rail that has been leveled. Do you see the picture?
  1. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
  2. Linear rails
    By lgalla in forum Linear and Rotary Motion
    Last Post: 08-22-2006, 09:48 AM
  3. Enco or Mitutoyo test indicator?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 01-03-2006, 04:38 PM
  4. what does dial indicator use to measure?
    By cnc2k in forum MetalWork Discussion
    Last Post: 07-16-2005, 01:20 PM
  5. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
