567,245 active members*
3,881 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > dialog documementation needed (dlg, dlgname, dlgshow)
Results 1 to 1 of 1
    Nov 2022
    6
    Documentation for dialoge (dlg, dlgname, dlgshow) is still missing here at cnczone.
    Can anybody advise where to find description and parameters of these functions?
    Jan 2022
    98
    Re: dialog documementation needed (dlg, dlgname, dlgshow)
    As I Know there is no documentation available right now. But you can find some examples when searching for "dlgname" in this forum.
    Here is what i got so far
    Always start with (dlgname,Dialog Headline here)
    Content goes here...
    Always end Dialog with (dlgshow)
    Adding opt=1 hides cancel button:
    (dlgname,Dialog Headline here, opt=1)
    Add Text
    (dlg,my Text, typ=label, x=0, w=410, color=0xffffff)
    Add input field
    (dlg,Bezeichnung, dec=3, def=-20, min=-1000, max=1000, param=length)
    or
    (dlg,Distance, x=0, dec=2, def='setunit(10, 0.5);', min=0.1, max=10000, setunits, store, param=dist)
    (dlg,./Icons/Warning.png, typ=image, x=0)
    Checkbox (may contain multiple elements separated by |)
    (dlg,|Yes|No, typ=checkbox, x=50, w=600, def=1, store, param=option)
    with linebreat before "option3" with \
    (dlg,caption|option1|option2|\option3|option4, typ=checkbox, x=20, w=90, def=1, store, param=action)
    param= parameter where to store result
    def= default value
    dec=decimal places
    x= left distance in pixels
    w= width of item. per Item in case of checkbox
    Moderator
    Mar 2017
    1162
