603,894 active members*
2,818 visitors online*
Results 1 to 4 of 4
    Apr 2023
    Question Did I destroy my ways?
    I bought a 5019 CNC and things were great. Then they weren't. Turns out I was not using transmission fluid as oil like I thought. I was using some weird additive instead:
    https://www.amazon.com/Lucas-LUC1000...ts_id=15719641
    Cleans and lubricates sticking? Sounds good!
    So yeah, now my ways look like this:
    https://i.imgur.com/Mh0Re4D.jpg
    The shiny part is where the brass gib slides. Everything else feels coarse. I can't wipe it off with acetone or WD40. Not sure what that is at this point. Is it just scratched up?
    Thanks!
    Apr 2004
    5951
    Re: Did I destroy my ways?
    It doesn't look that bad to me. When you reanointed it with the proper lubricant, did it move smoothly?
    Andrew Werby
    Website
    Apr 2023
    I can't feel it binding up. I don't remember how easy the motion was when I first got it, it seems like it may be a bit more difficult now. I am mainly concerned about it getting worse over time if I continue to use it as-is. Otherwise I would be fine.
    Apr 2004
    5951
    You might check the tightness of the gibs; rock it a little and see if it moves. If so, it probably needs adjustment. Here's a video that shows you how: https://www.youtube.com/watch?v=XHMS9FBBsx4 Run a sample program, and see if it loses steps. If not, lube it well and just keep using it until something does go wrong. If worse comes to worst, you can get new parts from Taig for reasonable prices - they don't gouge you for repair parts.
    Andrew Werby
    Website
  1. Inner hole scrap destroy cutting available now!!!
    By cutleader in forum CutLeader
    Last Post: 03-14-2019, 02:01 PM
  2. Will Power Drawbar destroy the ballscrews
    By skray775 in forum Benchtop Machines
    Last Post: 10-26-2018, 11:14 PM
  3. what are better dovetail ways or boxed ways?
    By CATCH22 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2010, 01:02 PM
  4. Switch to carbide drill = Destroy boring bars??
    By PoiToi in forum MetalWork Discussion
    Last Post: 03-21-2009, 08:27 PM
  5. Destroy the Economy, Destroy the World.
    By AMCTony in forum Environmental / Alternate Energy
    Last Post: 01-20-2008, 06:21 AM
