603,822 active members*
6,171 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > difference between servo motor and spindle motor
Results 1 to 5 of 5
    Oct 2006
    15
    What is the difference between the two?
    Dec 2003
    24260
    In the very general sense, the servo motor provides precise positioning control by use of a feedback element, for example encoder or resolver, the spindle motor is velocity controlled.
    They both can consist of various technologies, i.e. DC brushed, AC Sinusoidal (synchronous) and Brushless DC, the spindle motor can also be a common AC induction motor type.
    In some cases the spindle motor can be made to accurately position by means of feedback to the controller for functions such as orientation for tool changing and can even be done with induction motor technology, usually 3 phase type.
    In the case of the servo motor, PID feedback loop allows interpolated moves between axis.
    Al.
    Albert E.
    Oct 2006
    15
    Thanks Al - I ask because I'm interested in converting an old gear hobber to CNC. I would need electronic gearing for that. In thinking about electronic gearing - where you try to sync two spindles, I figured there was no difference between synchronizing spindles and synchronizing two servo motors (X and Y axis). From what you say though, it sounds like synchronizing spindles would require a bit more position control then normally would be there.
    Dec 2003
    24260
    If thinking of electronic gearing you may have to use servo motors for the spindles.
    Controllers such as Galil will gear two or more motors off of a slave motor at whatever gearing you wish.
    Al.
    Albert E.
    Oct 2006
    15
    Ah, that's interesting. For a gear hobber I really don't need high speed for either of the two spindles. I'll look into using servo motors instead of spindle motors for the two "spindles" (hob drive and work piece drive).
  1. What's the difference between servo,stepper and a DC motor?
    By fraist in forum CNC Machine Related Electronics
    Last Post: 09-27-2009, 06:23 AM
  2. Servo motor used as spindle motor?
    By fatal-exception in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2007, 08:55 AM
  3. Newbie: is there difference between stepper and servo motor?
    By g888h in forum Stepper Motors / Drives
    Last Post: 09-11-2006, 01:50 AM
  4. Servo and conventional motor...what's the difference?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 04-21-2004, 03:01 PM
  5. Physical difference between a stepper,servo and a DC motor
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 02-23-2004, 05:40 AM
