thank you for sharing your knowledge. I have samsung csdj 200w position driver, and yaskawa sgm ac 200w motor. please help me to make this project running. can this be possible with different maker? please help!
Check to see if the motor has hall devices or commutation tracks on the encoder, if so check the drive for these inputs, if the voltage of the drive & motor is compatible it should work.
Al.
Albert E.
aztec
There are some that have done this, but this is not easy to do, as the Yaskawa Motor Encoder, Has software that the Drive has to recognize , if this does not happen
then it will not run
On connection to the correct Yaskawa Drive,some of the information about the motor Encoder is automatically set in the servo Drive
Each manufacture has a different setup, and most of the information is proprietary, so for the ease of use it's best to get the matching drives
Mactec54
