603,936 active members*
2,604 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > differential quadrature encoder
Results 1 to 10 of 10
    Jan 2014
    61
    On an Ajax Centroid system, when wiring a pulse generator, for manual axis control, that has a 5 wire + shield output, i.e. 5V+, 0V, A, B, Z wires, can the 0V be wired to the Ajax -A, -B, -Z inputs?
    Cheers, Colin
    Apr 2004
    61
    connect A and B only
    Enviado desde mi iPhone con Tapatalk
    Jorge B.
    jorbercnc.com
    Dec 2010
    5
    Sorry, I cannot answer your quewstion, but you post interest me. How does one add a manual axis control to a Ajax Centroid system?
    Jan 2014
    61
    You can buy from Ajax a plug in pulse generator on a lead, with switch to chose which axis the pulses will be sent to. In my case I already have a very good aluminium hand wheel and axis selection switch on my machine guard, in a perfect position for doing manual machining, or more normally setting the tool compensation and X & Z sizing. I want to buy an encoder and fit it to this handwheel, but have not yet found one with the correct pin output for the Ajax system. I feel that 0V can be used as all pin output negatives, but need this confirming.
    Cheers, Colin
    Dec 2012
    192
    One possible option could be to use a DS9638 Dual High Speed Differential Line Driver. I use this chip to generate differential signals out of single ended ones from encoders. They are 8 pin chips requiring 5 volts. The following link downloads the spec sheet.
    https://www.google.com/url?sa=t&rct=...59026428,d.cWc
    While I don´t know the Ajax systems I´m quite sure that if it requires differential inputs using two DS9638´s will fulfill your needs. Just remember to use one 100uF/16V and one 0.1uF/50V between the power lines (5V to GND) in your PCB to filter out possible electric noise due to the interconnection.
    I hope this helps. Good luck.
    Sep 2010
    1765
    Quote Originally Posted by howanc7 View Post
    Cheers, Colin
    NO control will see that as loss of enc sig. see bbmx's solution or buy right encoder and a new cable with enough wires
    Jan 2014
    61
    I have done a lot more reading now, and will be looking for the correct differential quadrature encoder, to fit to my existing graduated handle. I guess there are not many short cuts in this world LOL.
    Regards, Colin
    Jan 2006
    2985
    There are many shortcuts, you just have to know where to look. Here is one shortcut for you: US Digital | Products » EA Incremental Encoder Adapter
    Input 5 pin connector for your encoder. Output 10 pin connector for your differential inputs on your control.
    Matt
    Dec 2003
    24260
    As in post #5 there are a few IC's out there that will convert single ended to differential for a few ¢ and a small strip board.
    Al.
    Albert E.
    Jan 2014
    61
    Thanks every one, it has now been confirmed by Ajax, that for my manual pulse generator input, I don't need the Z output (nothing to reference), so I will be using a chip to make the A & B, into A+ A- and B+ B-. Seems the best solution, as I have a spare of the original one fitted to the machine, so won't need any mechanical changes and will have a spare on the shelf.
    Regards, Colin
  1. differential vs. single-ended quadrature encoder?
    By postvmvs in forum CNC Machine Related Electronics
    Last Post: 02-19-2014, 11:14 AM
  2. Kflop/Quadrature Encoder Use
    By islander261 in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-20-2013, 08:20 PM
  3. Quadrature Encoder readers
    By willofgod in forum Digitizing and Laser Digitizing
    Last Post: 12-06-2012, 09:10 PM
  4. Quadrature Encoder Question
    By Harry_Y in forum CNC Machine Related Electronics
    Last Post: 10-17-2011, 10:39 PM
  5. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
