Well guys ....
Figured I would post this up and get some feedback on it.
Maybe Alan can use it for a guide to create a DigiKey parts list for the site.
Pretty certain everything is correct but any corrections/suggestions are certainly appreciated.
Resistors
10K 1/2 Watt
R5, R6, R7, R8, R9 : PPC10KXTR-ND
10K 1/2 Watt
R1, R3 : PPC20KXTR-ND
8K 1/2 Watt (see readme for your value)
R2, R4 : PPC8KXTR-ND (Based on a 2.5A motor)
The three part numbers above are not currently listed online but are in the catalog on page:
http://dkc3.digikey.com/PDF/T052/1060.pdf
Alternate number: "PPC" + Value + "BCT-ND" .... Values= 10K , 20K , 8K
On Page: http://dkc3.digikey.com/PDF/T052/1060.pdf
Capacitors
.0022UF 100V METAL POLY
C1, C3 : 495-1134-ND
50V 560PF AXIAL CERAMIC C0G
C2, C4 : 1008PHCT-ND
1.0UF/100VDC METAL POLY
C5, C7 : E1105-ND
470UF 63V ELECT HE RADIAL
C6, C8 : 493-1646-ND
100UF 16V ELECT PW RADIAL
C9 : 493-1779-ND
.01UF 100V METAL POLY
C10, C11 : 495-1138-ND
Semiconductors
U1 : PIC16F628A-I/P
U2, U3 : LMD18245T-ND
Sockets, Headers, Switches
CONN HEADER 6POS .100 VERT TIN
CONN1 : WM4204-ND
TERMINAL BLOCK 5MM VERT 2POS
CONN2 : ED1601-ND
TERMINAL BLOCK 5MM VERT 4POS
M1 : ED2233-ND
CONN HDR BRKWAY .100 80POS VERT (1 part is enough for 4 boards)
CONN3 : A26534-ND
SWITCH DIP FLUSH TAPE SEAL 8POS
U4 : CKN3070-ND
U1 Socket : ED3318-ND
Alternate numbers:
CONN3 : A26268-ND (1 needed per board)
U4 : CKN6037-ND
That is what I have come up with based off the Jaycar list on Alans site.
But by no means is it a set list yet - would like some input on it to make sure every thing is ok.
:wave:
