588,604 active members*
7,987 visitors online*
Results 1 to 9 of 9
    Mar 2005
    8
    Cool digiplan sd3 drives
    Can anyone tell me the Voltage input for step inputs? at the connector? I have no indexer and am trying to run the pulse at 5V no luck. Where might I find a schematic for this
    Feb 2004
    813
    Are you sure it has step inputs
    Most servo amps need +/- 10v
    Mar 2005
    8
    Yes it is step and direction. It has an internal oscillator that you can hook up the step input to and the drive works fine. I can't however determine the voltage I don't have a scope. I am trying to run it from Mach2, with a soundlogid reakkout board.=b step and direction 5V setting on the step. I have tested the PC side and the sound logic breakout board with another (PacSci) drive that takes a 5V step input and it works fine. So I know the setup is good. I just cant get the SD3 to respond to the 5V. I have a feeling that it needs 12v on the input and the drive is taking that to 5V TLL level on the board. I am just not sure. Unfortunately I am not an electrical engineer, and can't get to board level with my current understanding. The book states the indexer is sending 12V. I dont have the indexer board, and can't find one
    K
    Apr 2004
    56
    Hi Ken,
    Maybe I can help. I use the Parker Digiplan PK2 drives on my mini-lathe. They need a 12v signal to work. You can take the 5v up to 12v with a 3.3k resistor and a 2N3904 Transistor on each line. I attached a diagram from my manual, hope it shows up. I can't say that this will work for yours, but it sounds like it will.
    Tim
    Mar 2005
    8
    Hey! thanks so much. I think i can put this together. You are a lifesaver. I will let you know how it works out.
    Ken :banana:
    Sep 2006
    Hi, I am trying to convert a 5v pulse to 12v. do i need to connect 12v to the circuit and where.
    thanks harry
    Jul 2005
    442
    Quote Originally Posted by harry59 View Post
    thanks harry
    You can use one of the charge pump RS-232 trancievers, this will get you to ~10 volts but not 12
    The easiest way would be a couple of BJTs and a 12 volt source.
    Aaron
    Mar 2007
    If its to drive the SD3 all you need is an open collector drive as the SD3 has pullups to +12V
    You can use discrete transistor or a 7406 or uln2803
    Regards
    Anthony
    Feb 2008
    243
    Re: digiplan sd3 drives
    Quote Originally Posted by arwooldridge View Post
    Regards
    Anthony
    HUH! The parker manual for the digiplan sd3 says that the step voltage is 5V and must be greater than >3 and <8 VDC..
    Dan Mauch
  1. "Dumb" drives vs. DSP drives and cost
    By Windscreen in forum Servo Motors / Drives
    Last Post: 05-01-2014, 02:49 AM
  2. PKS Digiplan Schematics Required
    By GT390 in forum Servo Motors / Drives
    Last Post: 03-30-2012, 12:10 AM
  3. Parker Digiplan CD10 stepper driver
    By Paul Townsend in forum Stepper Motors / Drives
    Last Post: 08-08-2011, 06:29 AM
  4. Replies: 4
    Last Post: 01-16-2011, 03:22 PM
  5. Replies: 1
    Last Post: 07-24-2005, 12:31 AM
