I have a mill with a digital-cnc retro fit. the software it uses is a dlx2000-10
the problem I have is that it is DOS. It has been sitting in the shop and using it as a manual machine.
I want to convert it to a controler that uses Mach3 software the motors are a shinano Kenshi
1.8 degree
2.8 volt
2.8 amp
6 wire motor
the controller lnly uses four of the 6 wires.
Does any one have an idea of a controoler that will be able yo use mach three?
thanks Clint Beyer.
