Wow - those babys aren't cheap!
I wonder -- has vacpress done any more on the DIY "microscribe" varrient? He was going to use mouse bits and build a robotic arm digitizer.
Sounds like a good compromise if you could get close and work the fit after the fact.
On a similar project (car interior) I am planning on using the existing doorskins and dash - digitizing the backsides (the side against the door/firewall), create a point cloud and then go from there - figured the machine would probably run for a couple of days to get just one door done. - but hey - might save some plotting time - mirror the left and right. Here's hoping GM did a fair job building!
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
