603,409 active members*
2,958 visitors online*
    Feb 2010
    Dimensional Tolerance
    We have a Digital Tool Meta Machine DR904. I have found out that this company is out of business now. Upgrades were done to the machine before we purchased it.
    My table is ~1/64 out of square diagonally when I cut a 12x12" square, which for cutting MDF, Melamine and Blue DOW foam that is accurate enough for our work. I just went 3d with it last week and now when I cut a 12x12" 3d tile it is off 1/4" diagonally.
    I have programmed the same tile to cut in .05" steps and in .125" steps. With both cuts I have roughly the same 1/4" off of square.
    I have checked all belts and connections for something being loose and haven't found anything that could be wrong.
    We currently are programming with Bobcad v19 and doing the 3D work in Rhino3D.
    My part is square in Rhino.
    I have checked the code to see if I am loosing the dimension somewhere in the numbers, but I could not find anything that seemed to be off.
    Attached are some pics.
    Has anyone had similar problems? Any ideas as to what it may be? I thought it was my X axis gearing, but I went in and checked all that yesterday and couldn't find anything wrong.
    Attached Thumbnails Attached Thumbnails 25079_670627480288_29705868_38515489_1777813_n.jpg   25079_670627585078_29705868_38515490_7485265_n.jpg
    Feb 2010
    Over the last 24 hours I have done some calculations of the code in the .tap file. I am pretty sure that I am having my problems in that area. My question now is: Does bobcad or WinCNC produce the X Y Z code that my machine reads? Or could it be the post processor - which I am not completely sure what or where that is. Once again my model is straight.
  1. Dimensional restoration
    By Chuck Cox in forum News Announcements
    Last Post: 01-09-2010, 11:20 PM
  2. ISO Tolerance Help?
    By Billet Sean in forum MetalWork Discussion
    Last Post: 06-18-2008, 01:04 AM
  3. Replies: 0
    Last Post: 12-05-2006, 08:57 PM
  4. tolerance
    By heilcnc in forum Benchtop Machines
    Last Post: 04-29-2006, 02:31 PM
  5. Dimensional ptoblem
    By Alex S.A in forum DNC Problems and Solutions
    Last Post: 04-19-2005, 02:57 PM
