588,555 active members*
4,596 visitors online*
Results 1 to 6 of 6
    Jan 2015
    26
    Question Dirty cooling water
    The cooling water of my 2,2 Kw spindle is turning dirty brown rather quick. I've been using plane water and the spindle is made in China. Should i use any additive to avoid rust? Or is this oil / grease dissolving in the water? Do I need to lubricate the spindle regularly? I have not used the machine for a month or 2 in summer and did not remove the cooling water in that period. I thought the brown durt would wash out after refreshing the water a couplde of times but it still seems to get dirty again after a couple of hours of milling. The spindle runs fine, and remains cool, no strange noises. Should i worry?
    Thanx
    Feb 2006
    7063
    Re: Dirty cooling water
    You should be running some corrosion inhibitor in the water. Automotive anti-freeze mixed 50/50 should work well.
    Regards,
    Ray L.
    Jun 2004
    6618
    Yeah. Anti-freeze or coolant is already engineered to basically do the same job in a vehicle.
    Lee
    Jul 2004
    1424
    Tormach sells a lubricant/corrosion inhibitor for your cooling loop:
    35553 - Water Chiller Treatment, 8 oz.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Mar 2014
    1133
    I wonder who and why deleted my post.
    Sent from my GT-I9300 using Tapatalk 2
    Jan 2015
    26
    Hi guys, thanx for your advise.
    How stupid can I be. If been using this additive in my manual mil for years. But in the enthusiasm of getting my CNC started I just forgot about it.
    I guess the best would be to dismantle and clean the whole spindle and then start running with the additive.
    (Azalin, not sure what has been deleted, can you repost?)
    Best
    Lawrence
  1. Dirty cooling water
    By notexpert in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2010, 09:35 PM
  2. Laser Cooling water
    By pete00 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-10-2009, 08:21 PM
  3. Water cooling CPU
    By cncadmin in forum Computers / Desktops / Networking
    Last Post: 07-13-2006, 11:30 PM
  4. water-cooling air torches?
    By anthony in forum Waterjet General Topics
    Last Post: 05-01-2005, 09:51 AM
  5. water cooling
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-02-2005, 12:13 AM
