Hello All,
so I was being a stupid idiot and managed to drop the carriage while the plastic slidey retainer was middle way out of the bearing. After that the balls spread out like wildfire and went into all the floor cracks possible. So I decided to take the carriage apart to find what kind of balls I would need to replace the lost ones. As best as I could tell, the balls are either 3.16 or 3.165mm in diameter. This is actually very close to an imperial size - 1/8th of an inch or 3.175mm.
So i guess my main question is can I substitute all the balls from 3.16(5) mm to 3.175mm and just have a bit more preload or will it not fit? Or will it fit and just wear everything out much faster?
Thanks and video below
