603,940 active members*
2,350 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Display settings (Resolved)
    Jan 2007
    206
    Hi all,
    I'm having a problem with my graphis in X3!
    This is a new PC(all new hardware) with the latest drivers for Vista x86
    I'm almost unable to use OpenGL cause it keeps on drawing when moving the mouse.
    I have an ATI Card and am aware of problems they had in earlier versions but I'm stumped now??
    I have tried to apply the Nvidia workaround with no luck.
    I've tried changing some setting, again! No luck??
    Has anyone else got that problem?
    All comments made are my opinion!
    Jan 2007
    206
    Problem is resolved! I’m thinking “bad install” I originally saved the settings and I guess although the Disable Hardware acceleration was checked it somehow must not have worked correctly. I did a clean install and checked the box again and now everything is working like it should.
    I figure I let everyone know just in case it happens to someone else.
  1. Mills on Display?
    By Andre' B in forum Charter Oak Automation Support Forum
    Last Post: 08-14-2008, 01:07 PM
  2. Coordinate Display
    By Regnar in forum LinuxCNC (formerly EMC2)
    Last Post: 07-12-2008, 09:07 PM
  3. RPM display
    By fatal-exception in forum Mach Mill
    Last Post: 11-24-2007, 10:02 PM
  4. Set the counter display
    By hien100881 in forum Fanuc
    Last Post: 09-22-2006, 05:26 AM
  5. Display following error
    By Rocksalt in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-29-2006, 01:57 PM
