603,400 active members*
2,353 visitors online*
    Apr 2013
    1780
    Display a variable
    I'm sure that my question has been answered before but I can't find it with the search tools. I apologize in advance.
    I have hand generated some Gcode to do 3D milling of a strange shape. It takes a while to run so I would like to display progress in the Status line. The ideal would be something like "( depth = #99)" where the #99 variable contains the current pass depth. This doesn't work because the "#99" is not parsed within a comment. I am aware of suggestions such as Display a variable on the status line However, is there any easy way to display the current value stored in a variable?
    Apr 2013
    1780
    Re: Display a variable
    I suppose that it is bad style to answer your own question but... If you choose Operator ==> GCode Var Monitor you can do what I need. My excuse for not knowing is that I have a Tormach and they've deleted that menu choice from their customized version of Mach! Any knowledge of problems that result from using the GCode Var Monitor menu choice?
    Oct 2005
    1145
    Are you allowed access to the macropump in the Tormach system ??
    (;-) TP
  1. Mazak Fusion 640 Local Variable Display
    By ggborgen in forum Parametric Programing
    Last Post: 10-31-2010, 09:33 AM
  2. Variable zero
    By Dave Elliot in forum DNC Problems and Solutions
    Last Post: 05-28-2010, 10:38 AM
  3. Variable changes
    By TNorbut in forum Controller & Computer Solutions
    Last Post: 07-23-2008, 01:16 PM
  4. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
  5. IF variable = bla THEN do this ELSE do that ?
    By iMisspell in forum G-Code Programing
    Last Post: 07-31-2006, 04:57 AM
