If you are doing like was suggested to you on the MecSoft forum - a possible issue I can see is with the point creation part way into your part (ie at the bottom of an existing Counterbore). VM MAY (?) see this point as being clear of your part (depending on how your clearance planes are set(and also hole creation MOPs can be finicky as to what is actually the top of your part)). I generally like to draw my hole points on the top surface of my part and then calculate the hole/pocket depths from there.
I would like it if hole creation MOPs had a "pick" box for selecting top Z level.
www.integratedmechanical.ca
