588,058 active members*
5,758 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Diving into spindle bearing replacement
Results 1 to 6 of 6
    Jan 2011
    171
    Hello - I have a JCUT Router (chinese). After less than 200 hours my 4.5kw water cooled spindle (single phase, 220v ) wore out the bearings. There are a few factors that could have contributed including the quality of the spindle itself. On several occasions the water was not running and the spindle got quite hot, the application I use the machine for is pretty arduous (material removal with a long extension) and I don't have a dust extraction system. You will see in pics. I am relatively new to machining and so I just don't know what to focus on so that I can get better tool durability in the future. finally, i was told that this spindle should have a bearing ring to reduce wear caused by electrical "surges"? does that make sense and is it is a significant consideration?
    Attachment 248630 this is the spindle with extension and 1.25 inch cutter.
    general questions about re-assembly and bearing "tightness"
    Any help would make a huge difference. Thanks in advance!
    Jan 2005
    15362
    Re: Diving into spindle bearing replacement
    danielcoyle
    The bearings should not be very tight on the shaft, as you have them mounted, how tight were the original Bearings, the fitting of the new Bearing should be the same fit, are your new Bearings Sealed, if they are then they already have the correct amount of Grease, no more grease is needed, if the Bearings are open then they will need the correct measured amount of high performance Grease ( kluber 15 )
    When fitting Bearings like this, you have to measure the Spindle Shaft & the ID of the Bearing, & make sure they are the correct size before you press or slide them on, if they are to tight a fit on the Spindle Shaft, then they will not last very long
    Mactec54
    Jan 2005
    15362
    danielcoyle i was told that this spindle should have a bearing ring to reduce wear caused by electrical "surges"? does that make sense and is it is a significant consideration?
    It has nothing to do with electrical surges, & it is a Grounding Ring for the Rotor, do a search about the use of VFD's & Rotor Grounding
    Mactec54
    Jan 2011
    171
    mactec!! you are everywhere! thanks. the new bearings are the exact same type/id as the old ones. they are sealed bearings. they were installed/pressed on in the same orientation as the old ones. the old ones (before i pulled them off) spun on the shaft a little easier than the newly pressed on ones do. everything else seems/looks the same.
    i guess i am wondering about the grounding ring because i have never heard of this before and, in addition to my wonderings about overheating the bearings by not having the water running and overworking the bearings because of the way i was using the machine this grounding ring thing is just another variable in the mystery of "how did i wear these out so quick". i guess i am really just overwhelmed at trying to figure out the best way to prevent this from happening again. why don't spindles just come with grounding rings on them (do other spindles, 3 phase for example, not need this)? if i had used the machine regularly at all the company would have been on the hook for a warranty situation, assuming it was the grounding ring that would have saved them? is there a way, from inspecting the worn bearings, to determine if the damage was mostly a result of improper mechanical loading, heat or lack of grounding ring?
    Jan 2005
    15362
    danielcoyle
    The Bearing ID can change depending on the tolerance the manufacture uses, if they were tighter than the one's that came off, then they had a different size ID than the old Bearings, it only take a very small number (microns) to be either to tight or to loose, that is why they have to be fitted/measured to the shaft the are going on, if they are to tight, they will over heat
    The Grounding ring just Grounds the Rotor voltage, without it, this voltage goes through the Bearings to Ground, & eats away the Bearing surface, ( electrical discharge ) this happens in all VFD driven AC Motors
    The running without water will also cause your Bearing to over heat, & the lube/Grease would run out, they will ware out quickly without lube, at the high RPM's they are running
    It is easy to take apart the AC Bearings, to inspect the bearing races, you can rotate the center of the Bearing, outward, so you clamp the outside of the Bearing,(in a vice ) with a Steel Pipe or Bar a close fit on the inside of the Bearing, use the Pipe/Bar to lever the center of the Bearing out with a twisting action
    Yes quality VFD driven AC Motors/Spindles have the Rotor Grounding Built in
    The use of your long cutting Tools would not of been any part of early Bearing Failure, over heating would of been #1 then the Rotor Grounding as #2
    Mactec54
    Jan 2011
    171
    OK. So, here are a couple videos of how the new bearings behave after being put on the spindle shaft and then after being tapped into the spindle body. In both cases they are tighter than the un altered spindle. What, if anything, should one do?
  1. Perske spindle bearing replacement-how?
    By Stewey in forum Maintenance DIY Discussion
    Last Post: 08-28-2021, 10:31 AM
  2. Bearing replacement for 2.2kw spindle (need bolt)
    By ricowind67 in forum Spindles / VFD
    Last Post: 01-16-2014, 07:11 PM
  3. Hardinge spindle bearing replacement?
    By vpmachine in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2010, 12:37 PM
  4. Spindle Bearing Replacement
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2009, 12:12 AM
  5. Spindle bearing replacement
    By Rich 72 in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2008, 06:12 PM
