Precision Plasma LLC is a company with a philosophy of providing low cost tables to hobbyists and small business owners. By providing only the mechanical system, it allows the consumer the ability to choose the electronics and software packages to best suit their needs and budget. It also allows for the ultimate cost of the complete package to be less than if everything was purchased from a single company.
Why is it less expensive?
Product liability insurance is based on a company's total sales and the level of hazard of the equipment. By not selling the plasma units or electronics, the total sales and hazards are reduced. This reduces the cost per table.
Support is very expensive. The mechanics of a table requires very little support if good documentation is provided. The electronics and software is much more complicated and accounts for 95% of the questions.
You can choose the level of support you want if you have the ability to choose the electronics and software packages. Purchase a Bladerunner kit from Candcnc.com and you are purchasing support. (phone and e-mail) If you already understand the electronics and software you want to use, piece together your own system and save money. The information provided on the cnczone helps people research and understand the different options which allows them to make choices to fit their exact needs.
Precision Plasma 4' x 4' DIY CNC Plasma Table and Gantry Kit
Specifications:
  • 52" x 54" travel
  • V-guide wheels
  • Welded tube frame
  • Interlocking slats
  • Powder coated and plated
  • Floating Z axis for "touch and go" plasma cutting
  • Arm for cable management
This is a direct drive plasma table which requires (4) nema 23 276in-oz motors or greater to function. 1/4" shafts on the motors are required.
This table was not designed as a dual purpose machine.
Performance:
1000IPM rapids
50in/sec/sec acceleration
.001 resolution with 1/10th microstep drives
High resolution pictures available at http://www.chacich.com/original
Video available at [ame="http://www.youtube.com/watch?v=AyhV4oLOHEg"]YouTube - Precision Plasma CNC Cutting Table[/ame]
website http://www.precisionplasmallc.com
Documentation for the table http://chacich.com/pdf
The sell price of the table is $2995
Shipping and crating are additional charges if required.
The electronics and motors will cost anywhere from $600 to $1500. They must be sourced from another vendor.
The tables are produced in the USA and can only be sold in the USA.
Best Regards,
Ron Chacich
Also available:
Gantry kits 2' x 3' to 5' x 10' (different design than above)
Belt reduction kits
In development:
Economy 4' x 4' bolt together table
Rotary chuck
