Yes, maybe just using a hacksaw frame would make tensioning easier. I can refine the mounting after proving the concept. The windshield wiper motor is a nice idea. Let's have a look at that.
-James
-James
James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
Ok,
I bought a couple of linear motion carriages on ebay for a good price. One of them should serve to move the block of recon stone back and forth. Now I need to design a holder for a saw frame that that can move back and forth. I am thinking about using a timing belt between two ball bearing pulleys. One pulley will be direct drive by a stepper motor so I can control the motion and easily reverse it.
Any recommendations for sources for the belts and pulleys?
How can I mount the saw frame to this assembly?
-James
Just a thought on design ideas,to use the continuous wire rolls.
Have a look at the mechanics of a wire fed EDM.
Model engineers workshop mag had a DIY plan.
WJF
The More I Learn The Less I Seem To Know
Thanks for the idea! I am moving forward with individual wires for now, but I may go back to spools in the future.
My linear slides are in the mail! I found the timing belts and drive pulleys on smallparts.com.
I think I can mount the wire in a jeweler's saw. I have lots of those!
Moving ahead...
-James
you can buy high quality diamond wire saw with cheap price from our company website address: www.wire-saw-machines.com
why not get a band saw and replace the blade with diamond wire. i would think the reciprocating idea wouldn't be ideal as the tiny length of wire would wear out to fast and heat up to fast.
__________________________________________________ _________________
http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress
Diamond Wire saws are typically used wet. There are diamond bandsaws but they don't have a depth of cut for my application. I want to slice 5" x 6" pieces of recon stone from a block 5" x 6" which is 3" thick. If possible I don't want to have to process the sheets by thickness sanding them before I cut them.
-James
so have the lower wheel run a water reservoir.
you can cheapo band saw to accommodate 6in no problem
Did this project ever get off the ground? I have a need for a very similar device...
No,
I have decided to (eventually) build a wet horizontal bandsaw mill type of device.
-James
