603,370 active members*
3,818 visitors online*
    Dec 2006
    3
    DIY DRO Project
    I've decided to add a DRO to my lathe and mill Maximat Super 11 and V10P with milling head. I priced out a couple of packages from DROPros but I'm not ready to shell out 2 grand. I like magnetic scales, you can cut them to size and making your own is doable.
    I'm going to use the AS5306 or the AS5311 IC's in 'A' (push/pull output). I'm not sure I need 2um (AS5311) accuracy 15um might be good enough and it's a lot cheaper! $3.00 a foot from Maker.
    I'll try the 15um first (1.2mm pole) and if it's not accurate enough I'll have to go to the 1mm pole 2um tape:
    here's a link to a 2um tape: (1mm pole)
    DMB-A series magnetic stripe(Pole pitch:1+1mm) at $72.94USD in Instrument Parts & Accessories Directory on JointChoice.com
    about $72.00 a meter.
    I'll make the boards in Proteus and I already have plenty of microcontrollers and LED displays to make a nice display board and case.
    Any input is greatly appreciated, especially by some of you who have done projects like this.
    Rob
    Dec 2003
    24260
    Looks an interesting product, I see the strip available, I wonder if there is the rotary format for encoders?
    Also it has possibilities to include BLDC commutation, maybe?.
    Al.
    Albert E.
  1. First cnc project
    By chester1957 in forum Stepper Motors / Drives
    Last Post: 01-04-2008, 03:59 PM
  2. First cnc project
    By chester1957 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-25-2007, 09:48 PM
  3. DIY Project with MDF
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 01-08-2007, 08:57 PM
  4. My CNC project
    By eitanwaks in forum CNC Wood Router Project Log
    Last Post: 01-03-2006, 03:02 PM
  5. RC toy project
    By JRoque in forum Hobby Discussion
    Last Post: 12-30-2005, 08:49 AM
