587,571 active members*
3,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > DIY estop question. Currents don't add up.
Results 1 to 7 of 7
    Jan 2007
    94
    I'm almost done with an enclosure for my 770, and realize I probably need another estop outside. Since the 770 says it needs 20A service, I figured I needed a 20A estop switch since all of the machine power goes through that switch (yes?). After not being able to find one rated for 20A, I looked inside the control cabinet and see the estop switch Tormach uses is only rated for 10A. I guess 10A must be OK, but this seems to not add up. Can anyone clarify?
    Dec 2003
    24220
    Re: DIY estop question. Currents don't add up.
    I am not familiar with the 770 but the general rule is a E-stop string is carried out with low voltage, 24vdc being popular, the end result is a large relay or in the case of 20amps, a contactor should be used to drop out any significant power.
    This is the industry way of doing it. Unfortunately most hobby machines do not conform to this method.
    Al.
    Albert E.
    Jun 2014
    1780
    I have an 1100 and the power is dropped out with a relay, maybe an amp or so thru the switch.
    mike sr
    Jan 2007
    94
    Thanks. That makes a lot more sense.
    Jul 2004
    1424
    Quote Originally Posted by Al_The_Man View Post
    I am not familiar with the 770 but the general rule is a E-stop string is carried out with low voltage, 24vdc being popular,.
    The estop has 120V running through it (not 24V), and the only load powered off it is the machine control board and the C1 & C2 contactors. It is protected by a 2 amp fuse. So... much less than 1 amp.
    Other than that, Al is right and all the large loads in the machine are powered directly when the contactor (C1 or C2) contacts shut. The stepper motors and the VFD are all powered through contacts on the contactor, with power coming from 120V (VFD) and the 120V/40V transformer and DC bus board.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Apr 2013
    1788
    Quote Originally Posted by popspipes View Post
    I have a 770 and, like the 1100, the power is controlled by the eStop switch and relay. Certainly no need for a 20amp switch!
    Aug 2009
    986
    It it helps, I used this switch to add a second E-Stop to my Series 2.
    http://www.automationtechnologiesinc.../e-stop-switch
  1. Replies: 14
    Last Post: 05-04-2015, 02:21 PM
  2. EStop "Stuck", also parameter question
    By Bill Gillen in forum Colchester Tornado lathes
    Last Post: 09-04-2013, 06:02 PM
  3. estop
    By eloid in forum CNC Machine Related Electronics
    Last Post: 02-16-2009, 03:23 AM
  4. Estop
    By HuFlungDung in forum CamSoft Products
    Last Post: 03-06-2004, 08:24 PM
