587,226 active members*
3,080 visitors online*
Results 1 to 8 of 8
    Aug 2007
    422
    DIY flatbed printer ?
    I would like to build a machine to print designs on sheets of foam. the foam will be 3,6, or 9mm thick and be a sheet size of 27x39. I have several deskjet style printers laying around for parts. has anyone here tried this? Any info would be greatly appreciated!
    here is a link that is similar to what I want to make.
    http://hackedgadgets.com/2007/09/13/...atbed-printer/
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    Aug 2007
    422
    Anyone tried this?
    Aug 2007
    422
    umm... bump?
    Aug 2005
    578
    Well there is a similar build for a T-shirt printer. Including plans.... http://www.t-shirtforums.com/diy-dtg/t48651.html
    bob
    Oct 2005
    1238
    Arrow Foam Printer
    Quote Originally Posted by rcpilot82 View Post
    I would like to build a machine to print designs on sheets of foam. has anyone here tried this?
    This LINK will give some information that you might find helpful.
    Aug 2007
    422
    blackbeard, thanks for the link, it appears that they are keeping the same printing area for the t's. I am in need of something to print a 27"X39" sheet of foam.
    weldtutor, I have seen that link before. that machine cuts foam but does not print on it. I cannot see a way to convert it to printing without re-designing it.
    Thanks for the help guys, keep it coming! Once I figure out what I am doing I will do a build thread if there is any interest.
    Aug 2005
    578
    I would think you could buy a wide format plotter and add a movable table (with alteration) using the DIYDTG methods. The carriage mechanism is the only hurdle.
    Bob
    May 2024
    Re: DIY flatbed printer ?
    Resurrection of an old thread here...but has anyone pursued this any further?
    I've been thinking about trying to convert a large format printer to print on foam board (like available at Dollar Tree). I'm just curious if simply raising the print head carriage and various supporting structure with spacers (custom height, 3D printed) to change the gap to allow the ~5mm thickness of the foamboard to pass through. As far as the printer is concerned, it'll think it's still printing on "roll paper," unless there is some sensor that tells the printer the thickness of the paper it's printing on.
    Thoughts?
  1. Flatbed cutting plotter for packaging
    By Bread_O in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-16-2013, 06:14 PM
  2. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  3. My hacked HP printer flatbed
    By Graham S in forum CNC Machine Related Electronics
    Last Post: 06-02-2007, 11:31 PM
  4. Flatbed Plotter artistic use
    By Fozzie55 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-18-2006, 02:44 PM
  5. Printer for PCB ?
    By WayneHill in forum CNC Machine Related Electronics
    Last Post: 10-05-2005, 06:42 AM
