587,482 active members*
3,144 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Mar 2005
    13
    DIY plasma/router
    hello every one i love this site. with out this site i would have not even thought about building a cnc machine. i am posting because i am ready to start building my machine i have every thing except electronics and steel witch should be here this week(hopefully) i have some drawings witch i can post if anyone is interested
    Dec 2004
    312
    im always interested in other people's design and ideas
    Mar 2005
    13
    here are some of the drawings that i spoke of as you can see the y+z asises are not complete yet, i am waiting for the motors to turn up so i can finish that part
    Attached Thumbnails Attached Thumbnails CNCView1.jpg   CNCView2.jpg   CNCView3.jpg   CNCView4.jpg
    Sep 2005
    3
    Very nice design
    Hi! You do have a very good design.
    I am also planning to buid one; but right now I am thinking of a 6' gantry with electronics complete from Dynatorch. Then I will built the table.
    Seeing your sturdy design, I am thinking if it is wiser to just buy the electronics and built the gantry and the table.
    Btw any user out there of Dynatorch? How does it fare in usage since it is a DC servo closed loop system. In comparison with competitors it seems fewer people are using Dynatorch? Am I right in my assessment? Thanks for comments
    Dec 2004
    312
    i like ur idea for the grating part and why did u choose to have the table soo low? and what materials are u planning on cutting (max size) other than that the design looks good and will work.. did you ever find out how much that igus stuff would cost? i havent really contacted them yet but am wondering how expensive they are..
    Mar 2005
    13
    hi the finished table height will be 700mm to the top of the cutting surface ididn't want to have it any higher then that because it would be to hard to reach the centre of the table. i am planing to cut 1500x3000x12mm sheets of m/s max. the table travel is 1800x3300x220mm i have bought 3 x 6' lengths of igus chain these are the spics- open style side hinge cable and hose carrier 1.38"H x 2.87"w overall sz. 3.94" bend radius they cost me $90US each plus mounting brackets $27US a set. i bought these from mcmaster-carr
    Nov 2004
    30
    Really nice. What motor torque are planning to use to move the gantry?
    Just one motor to drive the gantry?
    Mar 2005
    13
    hi i am planing to use 2 closed loop servos 600oz-in
    Mar 2005
    13
    Table frame made! i have casters on the under side of table to allow me to move it around while i work on it
    Dec 2004
    62
    Great Job on the frame. What size frame material are you using?
    Herman
    Disclaimer: Not affiliated with any company or business. Happily Retired.
    Apr 2005
    3634
    terrydullaway,
    Your machine design, Looks very good.
    With your "X-axis" rails on the outside of the machine, It should prevent slag from getting on the rails
    Mar 2005
    13
    I am using 250X150X5mm RHS for frame, i used this size so that i can span 3600mm with out table flex.
    X axis bearings will also have a shroud covering them to further protect them from slag etc.
    Nov 2004
    30
    Great design . How did you make sure that the X axis rails are perfectlly parallel to prevent gantry binding?
    Mar 2005
    13
    I haven't fitted the x axis rails and rack up yet what you can see in photo's is a length of flat bar that i have plug welded into place, i have set the distance from the top of the RHS with a length of extruded aluminium flat and a lot of clamps and stops etc. I used a machine level to set the frame up when i welded it so the two beams should be in resembly good relation to each other. as for the bearings and racks i am getting aluminium tracks machined to hold them at the correct distance from each other and that will sit on top of the flat that i have welded to the side of the table
    Mar 2005
    13
    Just a picture of my progress
    May 2006
    3
    Hello terrdullaway i am from Bundy to. great job on the frame i have completed my 4th axis mill although not on the size of your machine. My machine travels are x500 y200 z450 stepper motor driven.
  17. #17
    Dec 2004
    312
    looks great and when do you think u will finish it?
  18. #18
    Mar 2005
    13
    My machine is all but finished all i have to do is finish the moter covers and bolt them on. i have had it running for about 6 weeks at the moment i have a router attached to it. Rabs how long have you hade your mill going
  19. #19
    Mar 2004
    500
    Lets see some pics!! Great job.
  20. #20
    Dec 2004
    312
    how long did it take ya to build that?
Page 1 of 2 12
