I just got a dc servo motor from ebay that was from a larger cnc machine. There is not model number on the motor but it has 3 cables comming out of it. I took apart the cover and 2 cables are for the brushes. There are 4 brushes on this motor and one cable (which has 2 seperate wires inside it) are on the front brushes which are larger and the other cable has 2 wires to the rear brushes. The other cable has 9 or so small 24 awg wires for the encoder which is a Renco model #77822-160. I was wondering if someone here can answer a couple questions I got?
1) How can I determine the encoder wires?
2) How do I hookup the brush wires to the UHU servo controller? Do I hook the front and back brushes in parallel or do I only hook up the front brushes by themselves? There is only 2 screw terminals on the board for the motor so it has me confused
Thanks for the help!
Bob
