603,781 active members*
2,465 visitors online*
Thread: DIY spindle
Results 1 to 11 of 11
    Aug 2004
    145
    DIY spindle
    Has anybody here made a spindle that accepts tool holders himself? e.g. ISO 30 or 40 taper etc?
    Aug 2004
    145
    Bump
    May 2004
    290
    I would if I had a lathe (and knew how to use one )...
    BTW
    What does "Bump" mean?
    Carlo
    Aug 2004
    145
    Quote Originally Posted by cbass
    I have access to a lathe and know how to use it. However I would like to know from someone who build one how tight tolerances are needed, what runout to expect etc.
    BTW
    Carlo
    It's meant to "bump up" the post to the top so someone will notice it (push it up).
    Nikolas
    Jun 2004
    487
    Did someone say "spindle"? 8 - )
    Start here and follow the link to the details. Hope that helps.
    JR
    Aug 2004
    145
    Sure it helps, thanks. My setup is going to be different but it helps to see that it can be homemade with good accuracy.
    I plan to use a 3ph motor with DIY VFD controlled from the PC and a belt drive. The taper will be for tool holders, not collects, since I want to make a tool changer with pneumatic drawbar, kind like the picture you posted here
    Aug 2004
    145
    What's the thread for the collet nut?
    Jun 2004
    487
    1.5mm
    Aug 2004
    145
    ?x1,5mm
    Major diameter?
    Jun 2004
    487
    32 x 1.5mm
    What motor brand/model and RPM will you be using?
    Cheers,
    JR
    Aug 2004
    145
    I'm still searching for the right ones. I don't need more than 7K rpm on the spindle. Thanks for the thread info
    Nikolas
  1. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  2. Diy Spindle Motor Controler
    By miljnor in forum CNC Machine Related Electronics
    Last Post: 11-06-2009, 05:01 PM
  3. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  4. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
  5. 2.2KW Allen Brad. Spindle motor?
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 02-02-2005, 06:46 PM
