588,624 active members*
5,412 visitors online*
Page 1 of 7 123
Results 1 to 20 of 123
    May 2008
    142
    Diy steel router build
    Have been reading this forum for some time,This is my first post so i will add some photos of my near completed steel cnc router.
    Will have to strip it down for its paint job when completed.
    Attached Thumbnails Attached Thumbnails DSC03671.jpg   DSC03713.jpg   DSC03737.jpg   DSC03752.jpg
    Aug 2007
    264
    mkc,
    Impressive build. What is your table made out of? Looks like you machined out some 4x4, 4x6 posts. Great idea, I may have to use it on ours. We're using MDF, but I'm always looking for better ideas.
    Mike
    Dec 2006
    277
    Very nice build
    Cheers, Bob
    http://www.ocm.com.au/wordpress/
    May 2008
    142
    Table top is a cheap method for now. 16mm MDF base with 40mm x 20mm pine timber on edge screwed from under side, then another one laid flat on top and screw down from on top, also pva glued then plain the whole tabe flat.make sure you leave a 8mm gap between rails for your claps to slide back & forward.
    May 2008
    142
    New diy control panel for cnc, also built in computer.
    Attached Thumbnails Attached Thumbnails DSC03799.jpg   DSC03791.jpg   DSC03789.jpg
    May 2008
    142
    Some more pictures of control stand
    Dec 2006
    277
    Very nicely done
    How was the ozito router mounted, we usually remove it totally from the frame and then just make an alloy clamp for it.
    Cheers, Bob
    May 2008
    142
    I have used a couple of angles to mount the router, Im not to sure how long this cheep router will last, so i will wait for a good router then will mount with a alloy clamp down the track.
    Here's a picture of my new driver card rack.(home made)
    Attached Thumbnails Attached Thumbnails DSC03814.jpg   DSC03815.jpg   DSC03816.jpg   DSC03818.jpg
    May 2008
    142
    Few more pictures of completed driver setup.
    Attached Thumbnails Attached Thumbnails DSC03826.jpg   DSC03828.jpg   DSC03830.jpg
    May 2008
    142
    Pulled my cnc router to peices ready for its paint job ,will post completed pictures when finnished.
    Attached Thumbnails Attached Thumbnails DSC03851.jpg   DSC03852.jpg   DSC03853.jpg   DSC03854.jpg
    Oct 2007
    187
    whose plans did you use? I am assuming you would recommend them. Your machine looks awesome.
    Jason
    May 2008
    142
    built and designed myself, tried to keep every thing inside the machine so there is one machine and a control stand, thats it !!
    If you live in perth i could help you with one.
    May 2008
    142
    DIY Control face
    Step1-Design it.
    Step2-Print it and cut out.
    Step3-laminate it.
    Step4-glue it on.
    Step5-trim and cut holes out.
    hope this will help some one...... mick
    Attached Thumbnails Attached Thumbnails DSC03876.jpg   DSC03870.jpg   DSC03873.jpg   DSC03877.jpg
    May 2008
    142
    Painted cnc mill
    cnc mill paint job finnished ,slowly putting it all back together.
    more pictures to follow.
    Attached Thumbnails Attached Thumbnails 08012009(022).jpg   DSC03882.jpg   DSC03887.jpg   DSC03888.jpg
    Oct 2005
    1238
    A great design & example of excellent welded fabrication!
    Thanks for sharing the photos.
    May 2008
    142
    Few more pictures.
    Attached Thumbnails Attached Thumbnails DSC03892.jpg   DSC03893.jpg   DSC03894.jpg   DSC03895.jpg
  17. #17
    May 2008
    142
    My pc and drivers are mounted to boards for easy installation,They just plug in.
    Attached Thumbnails Attached Thumbnails DSC03900.jpg   DSC03907.jpg   DSC03908.jpg
  18. #18
    May 2008
    142
    dust collector
    Made a dust collector that i found on the cnczone, Turned out ok .
    made two different size skirts for longer mill bits.
    Attached Thumbnails Attached Thumbnails DSC03922.jpg   DSC03923.jpg   DSC03924.jpg
  19. #19
    May 2008
    142
    completed cnc router
    few more pictures of completed cnc router.
    next project is a ER25 collet spindel.
    Attached Thumbnails Attached Thumbnails DSC03932.jpg   DSC03934.jpg   DSC03937.jpg   DSC03939.jpg
  20. #20
    Mar 2005
    59
    Quote Originally Posted by mkc2 View Post
    Very nice setup! Thanks for share.
    I like yours T-slot table too.
    Juka
Page 1 of 7 123
  1. Steel frame Ganrty router build
    By matth in forum CNC Wood Router Project Log
    Last Post: 10-30-2014, 08:32 PM
  2. Steel Router build 1500x1000
    By Bl@ckrat in forum DIY CNC Router Table Machines
    Last Post: 02-28-2014, 07:14 AM
  3. Steel 1.2m*1m Router build
    By Jtepper in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 08:20 AM
  4. New 4x8 Steel CNC router build
    By Ernie34 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2012, 01:41 PM
  5. First Router Build - 4x4, steel, R&P
    By cxixer in forum CNC Wood Router Project Log
    Last Post: 02-09-2008, 09:15 PM
