Hi guys,
I basically have a part that is just slightly too large in diameter for my outside roughing tool I usually use.
The idea was to use a inside roughing tool, placed upside down in it's support, and turn the spindle backwards for the cut. All good so far.
I programmed the machine, I defined a new roughing tool for exterior cuts that copies all the parameters of the inside tool I wanted to use. But when I run the program I get an error about tool change point.
The error is "correct tool change point; tool tip in"
Any ideas? Thanks, in advance!
( DMC CTX 510 eco - 2 axis)
