Trying to get the dripfeed up and running using FadalDNC-CNC software. Despite the normal loading of programs being no problem at all, I cant get the machine to get past the few-hundred-lines mark. Its as if the PC stops sending or the machine stops reading.
Settings are as per instructions, baud rate is 4800 (fastest that is error free!). Can someone please give a step by step of how they drip feed their 88HS? Thanks.
Suggestions on better software would be nice too!
Edit - Out of desperation I just left the machine to 'buffer' up for the last 30 mins, the progress bar is still at 1%. I guess this means the software is loading in only a small part ahead in the program. This could explain it as this is profiling, so its flying through the program at a rate far higher than I have seen it reading in. I cant get the comminucation to be any faster, is there something out there where you can set a buffer? The machine has 400-odd kb of memory, so setting it to read 350kb ahead seems like a good idea...
