588,201 active members*
4,401 visitors online*
Results 1 to 5 of 5
    Aug 2007
    7
    Dnc problem for Mitsubishi Meldas 520AM
    Hi,ALL:
    Our CNC machine controller is Mitsubishi Meldas 520am(very old), PC operation system is Windows XP. RS232 connection: CNC Machine---25pin---25 pin---converter---9pin---PC. My RS232 line is connected like the following:
    PC CNC
    1---------------------- 1
    3 ---------------------- 2
    2 ---------------------- 3
    7 ---------------------- 7
    6-8-20 6-8-20
    4-5 4-5
    I have no problem to send very very small NC programs to CNC machine using ConnectCNC.( Using Xon/Xoff flow control, baud rate 4800, data bits:7, stop bits:2, parity: even). Since the memory at machine side is very small (less than 100k), I try to use DNC, but don't succeed, with error "P460 TAPE I/O ERROR". ConnectCNC does not seem to care about whether the CNC machine is ready for receiving or not, and it just sends the NC program after the SEND button is pressed. It never waits for a Xon singal.
    The funning thing is that the machine can't receive a small NC program when I use " Wait for Xon" function in other software such as Cimco edit (same settings as ConnectCNC on both PC and machine sides).
    so my stupid questions are:
    Is the Meldas 520 using the same port for data receiving and sending?(There is only one port on machine).
    Which handshake is better for this old machine( Xon/Xoff or hardware handshake or no handshake)?
    Any suggestion will be appreciated.
    Thanks in advance.
    Feb 2007
    10
    you can try, " CncSimulator Ver 4,44f (2,7 Mb) "can download free version . http://www.cncsimulator.com
    25 pin------------------9pin
    1+7---------------------- 5
    3---------------------- 3
    2 ---------------------- 2
    4---------------------- 8
    5-----------------------7
    6-8-20 jumper 1-4-6
    Using Xon/Xoff flow control, baud rate 4800,data bits:7, stop bits:2, parity: even
    Mar 2003
    2932
    Are you using a laptop with a USB to Serial adapter? I've had problems with these trying to use XON/XOFF handshaking.
    Feb 2007
    10
    i am not using a laptop. i used standerd pc with 9 pin Serial port direct to machine side 25 pin Serial port.
    May 2010
    This a different topic but I am having trouble rigid tapping with this same controller. I get a different alarm with everything different that I try. Could someone please post a sample tapping program so I can see what I am doing wrong.
    Thanks in advance
  1. Mitsubishi Meldas 300-V
    By firestaromega in forum Computers / Desktops / Networking
    Last Post: 10-03-2023, 08:00 AM
  2. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2022, 07:12 AM
  3. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  4. mitsubishi meldas 50l switching to japanese
    By BAD DOG in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2007, 03:33 PM
  5. ask for help about connecting pc to mitsubishi meldas 50s
    By samhai in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-16-2007, 09:39 PM
