Typically to transmit the data after it has been programmed by software to a CNC machine, we need to have a computer and a tranfer adapter to connects directly (if connected via parallel port) with CNC machines .
This caused some defect:
Cost expenses: We will have to take some cost to equip a computerWasted place: Placing the computer in the production area is also a problem for businesses, we need approximately 2m2 for the placement. Moreover, the accessories such as wires, cables also cost areaInstability: If computer was infected, when transmitting data to CNC machine will do the wrong data (caused by virus) makes CNC be incorrect, or if one of the computer’s peripherals damaged also lead to instability THE NECESSARY OF DNC TRANSFER DEVICE
DNC Transfer Device is to transmit data to the CNC after being programmed. The inputs of this device is the USB port, Ethernet port or SD Card, we will copy the data after programmed into USB, memory card, (or transmit directly via Ethernet port) and plug in device DNC. The output of this decive is a RS232 port or parallel port, we need to supply power to devices through a adapter or take power directly from the CNC machine via RS232 cable or parallel cable
AdvantagesCost cheap: Using HIEPPHAT MICRO DNC will save a significant costDo not waste space: Due to compact so will not waste space in the production area.Stable, Simple operation and does not take much time, can work continuously for long time DNC Transfer Device
HIEPPHAT MICRO DNC is a device used to transmit programs for CNC machining (eg CNC milling machine, CNC Lathe, CNC Router, computerized embroidery machines ...). This transmitter is a compact design, paste directly to the CNC body by the magnet, not occupy factory area, quick and easy ... as alternatives to instead computers to transmit data to CNC machine
MICRO DNC HIEPPHAT compatible with CNC machines currently used in Vietnam as: all operating systems Fanuc, Mitsubishi, Yasnac, Okuma, Mazak ...
• Reads USB 2.0, SD card CARD of all brands and various capacities. • Has the memory of 2 to 4 Gb capacity depending on customer needs • Can be transmitted over the network via an Ethernet port or WiFi • Reading is the long file names up to 255 characters • Graphic LCD very intuitive • In addition to data transmission to CNC machines, MICRO HIEPPHAT DNC can take out programs, parameters ... from the CNC machine. • Automatic return to the first file after the trasmitting completely • Select the files you want to transfer in a list displayed on the LCD screen • Set the function and parameters with the button, displayed directly on the LCD Graphic, simple, intuitive • Speed baudrate up to 19.200bps (1200,2400,4800, 9600, 19200). Change the data transfer rate for parallel ports. • The warranty period is 2 years, the cost of repairs after the warranty period are low.SPECIFICATIONS
Name DNC Transfer Device - HIEPPHAT MICRO DNC
Orgin Hiep Phat Mechatronics
Features
  • Size: 140x100x30mm.
  • Weight: 300g.
  • Aluminum shell
  • 03 magnet
  • 01 DC power port.
  • 01 USB port.
  • 01 Sdcard port
  • 01 RJ45 ports
  • 01 port RS232
  • 01 LCD monitor
  • 05 buttons to customize
Power
  • 12V DC adapter
  • Or use electricity from the RS232 port or parallel port.
Compatible
  • All OS of Fanuc
  • Mitsubishi
  • Mori Sheiki
  • Yasnas
  • Mazak
  • Okuma...
Hightlight
  • Transfer data via port RS232
  • Read data/parameter from CNC machine
  • Read file from any USB
  • Read file with format *.TXT, *.NC, *.TAP.
  • Show % transmitted
MODEL
We provide 3 model of DNC Transfer Device
DNC Basic
DNC via internet (port RJ45)
DNC via WiFi
Read data from USB or devices memory then transfer to CNC machine via port RS232, this one is easy to use and cheap. Like the 1st one but it can read data via Lan connection (RJ 45 Port), using tools Hp TFTP to control.
Like the 2nd one but it can read data via wifi.
Advantages of Transfer data via network:
  • Remotely: Because it can connect directly via wifi, you may not need to direct handle it, you can control the device from a long distances, as long as it connect to wifi, you can perform tasks such as running the file, copy, delete, create folder on our software (Hp TFTP)
  • Send a message via the network: You can sends a message to DNC device from software, the staff can receive and follow
  • Sercurity: It lock USB port, does not allow retrieving data out, so when the operator control software used to run the file to transfer to the CNC machine, staff will not know which is unable to copy files and out, so will security information
Price : 120 USD
Price: 140 USD
Price: 160 USD
Contact:
Mail: [email protected]
or skype: tinnanh
