587,258 active members*
2,970 visitors online*
Results 1 to 8 of 8
    Nov 2003
    98
    Does anyone make a chip conveyor that works?
    Hello,
    I have been the Maint Supervisor at a machine shop for about 3 years now. Our biggest problems by far are chip conveyors. We have 140 Cnc machines, machining diecast aluminum for Honda automotive engines.
    Most of the machines are Nashida's with Bunri chip systems. We also have some Mazaks and Okuma's with Mayfran concept series.
    I honestly think we are making such a small chip that it never settles to the bottom to allow the conveyor to do its job. Im told that we cannot cut bigger chips due to surface roughness specs.
    Any suggestions on manufacturers that i can check out for future machines?
    thanks,
    Bob
    Mar 2004
    564
    HI, On some of our cnc's we use a paper like media that rides on top of a chain mesh conveyor. The coolant is filtered across the top of the media capturing oils and small chips and allows the coolant to flow through. Our other machines use long drag conveyors to allow the chips to settle, If someone tampers with the coolant flow to the tank we end up with turbulance and the chips are held in suspension and get sucked up into our priming pumps
    See if you can control the flow of coolant and allow the chips to settle if you can't change the conveyor??? just a thought........
    menomana
    Jun 2005
    Nov 2005
    274
    Try these folks too
    http://www.midbrook.com/hurricane_eq...ltconveyor.htm
    We have Turbo and Midbrook and the Midbrook are a bit more depenable
    But you are right the biggest problem with Aluminum is the chips float, It tooks us a few years to get it right. But all I can say is Filter Filter Filter.
    I acually eliminated the front drag on our Makino's all together and made a flume type system that the coolant flow takes all the chips to the side drag.
    And from there its Filter Filter Filter I got 2 sets of rosedales and went to a smaller screen in the side drag. But without the rosedales my nozzel and thruspindle would clog constantly
    Also keep your cooloant level a tad lower than you would normaly this helps evacuate chips better
    Jun 2006
    44
    Swarf or chip conveyors, contrary to popular belief are not a one size fits all package, sounds to me like you are using a conventional track conveyor when you really should have used a drag conveyor, if machining alumium at high speed was the the application you bought the machines for, then they should have supplyed the correct conveyor.
    Dec 2010
    For CNC Chip Conveyor
    Hello, Sir
    I'm kunal patel from Rajkot (Gujarat, India). We are manufacturing slat type chip conveyor and send it to some well known CNC manu. company. Our conveyor is perfect as engineering view. There is no compliant in working. So, we could solve your problem.
    Quote Originally Posted by bob1371 View Post
    Hello,
    thanks,
    Bob
    Apr 2013
    Hi..Though there are chip conveyors which work perfectly depending on the job you ve put it on. It needs maintenance like any other machine since it carries out heavy jobs of scrap handling. I think this is will resolve your issue. Chip Conveyors,Chip Centrifuge,Magnetic Coolant Filtration Systems,Paper Band Coolant Filters : Youtube channel : magtoolsindia's channel - YouTube .
    Cheers.
    Tushar
    Mar 2003
    2932
    The original post is from 2004. Probably has it solved by now.
  1. How do you make Bridgeport execute program?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2005, 02:26 PM
  2. Time to make it work
    By DESERT RAT in forum DIY CNC Router Table Machines
    Last Post: 02-22-2005, 02:30 PM
  3. pic chip SERIAL to step/dir and controll
    By berin in forum Open Source Controller Boards
    Last Post: 02-19-2005, 12:23 AM
  4. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
  5. How to make the frame exact
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 05-28-2004, 08:04 PM
