The HP 4000 is an older machine.
I do have manuals for an HP 5100.
Procedures are similar, but part numbers are different.
Here is the Mechanical Manual.
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
HP 5100
Here is the Electrical Manual.
HP 5100
ATC troubleshooting
APC Troubleshooting
DEAR MR.HARDT
THANK YOU FOR SEND THIS MATERIAL
IT WILL BE GREAT UTILITY
DHardt,
We are in need of any/all manuals for Puma 8HC-3A. Right now, we have only the parameters for this machine.
Hope you can help getting manuals - of course we are prepared to pay Doosan for paper manuals.
Cheers,
Steve Erickson
Puma 8HC is an older machine (Daewoo,) so I don't have the type of "teardown" manuals or Service manuals that I've been offering here, but Doosan Korea does have the older manuals available for purchase through Doosan America and our network of local Doosan dealers.
You will need the serial number from the machine, as the 8HC had many variations (It was sold for a long time)
Where are you located? (USA, Midwest is all that your profile shows)
You local Dealer is either:
JM Grisley - MT, ID, UT, Western WY
Ellison Technologies - MN, CO, SD, ND, NE, IA, Northern NM, Eastern WY, TX, IL, Eastern MO
Machine tool specialties - OK, KS, Western MO
Technical Machinery - AR
I don't have their numbers on me...
Hello, what do you have available for a DNM400 with a 12k spindle?
I have all the ones that came with the machine but if you have others
I would like to have those on hand also.
Thanks, Joe
The DNM500 Maintenance manual is available in a previous post to this thread. Attached here is the Alarm manual for a DNM500.
please help me for Doosan VTL 550 manual and accuracy test chart
please help me for Doosan VTL550 manual and accuracy test chart. i have used machine but i do not know much this machine have accuracy.
i bought old machine i need accurecy chart of this machine which we do not have also need operator manual for this
other are along with machine,
thankx for ur support
Hello Friends
Can any one help me with Doosan Old mc Probem with following details (Doosan ol m/c with no Model Plate,Even Fanuc Model is not Indetified)
Turret Declamp,Clamp and rotation Not Possible-No Coil Voltage On Solinoid Valves
Chuck Clamp Declamp Not Possible
Proximity Sensor LED not Glows (Ref,Turret Clamp Proximity LED are not glowing)
Last week Ive attended this call at that time Turret was rotting randomly in Jog /Index,However wrong Tool no in MDI
1st Ive checked Declamp /Clamp Coil Voltage was fine ,then ive reduced Hyd Flow which contolled mannual indexing one by one tool but MDI remained same problem (wrong Tool no) but during checking turret some time was not able to declamp at that time ive declamped by pushing Hyd Valve and indexing was ok .However next day Turret Clamp Declamp Chuck Clamp etc was not possible and Voltage on coils was missing.
Later on I found 2 PCBs on Which One Mosfet D525 was Short and on Second PCB 2 nos of Opto Couplers PC17 was open.but after putting new Components problem was same,Even 24 Voltage of Bridge Rectifier was okay ,Also Step down Transformer on one PCB (opto coupler) was shoing 6.7 Voltage and Rectifier on Same PCB 8 Volts DC.But Problem stil exists.
Actually I ve never worked on OLD controller and confused either these LED PCB (made by Doosan) are Input/Out Put or One I/p One O/p or relay PCBs .
If you have any single clue about These PCBs or exact circiut of DC voltage in use for Coils and sensors Pls send or help me with problem.
Thanks in Advance
hi,
i am a technical engineer, we bought cnc machine, daewoo puma 10s, unfortunatly, its memory card is damaged, i bought a card, and need the machine parameters.
please help me.
best regards
Can you provide ANY information as to WHICH machine it is?
If nothing else...a few pictures might help identify it...
If you want information about the Printed Circuit Board, please provide a part or spec number from the board...
(Please note: we don't fix boards, we replace them...new boards work better than old ones.)
Hi there
I don't suppose you'd have a maintenance manual, with alarms etc, for a Puma TT 1800, please? We have two of these and it seems the maintenance manuals only have gone walk about.....
Why, Oh why am I always in trouble?
I recommend re-purchasing the missing Instruction manuals, as they have helpful information in them.
Regarding teardown and rebuild service manuals for a tt1800, unfortunately I don't have one, but its systems and sections are similar to various other manuals that I do have.
An older TT1800 has a rear-mounted milling head like that of a Puma 240, a newer TT1800 has a front mounted milling head like a Puma 2100SY.
There are many other interlinks with other machines, so it would probably be best if we talked over the phone about your specific machine.
Darryl Hardt
Doosan Machine Tools America
Field Service Technician
973-618-2461
Looking for service manual for lynx220 exchange turret drive and motor.
Well thank you.
If Servo motor with drive (not hydraulic motor with encoder), then follow directions from the manual for the Puma 240m that is posed up-tread.
