587,593 active members*
3,814 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Does BobCad support Helicoil STI thread taps?
Results 1 to 9 of 9
    Oct 2009
    254
    Hey guys,
    I'm using V28. We have a job where we need to install M10 helicoils in aluminum. I have an M10 helicoil kit that comes with the STI tap. However in BC I don't see that these taps are supported in the thread type selection process. Is it possible to make this work?
    Thanks.
    Apr 2009
    3376
    Re: Does BobCad support Helicoil STI thread taps?
    sure,,,draw in 3D wire frame
    Mill in 3D engrave,,using a thread mill
    but
    I would use a tapping head,like a tapmatic,on a manual machine.Faster than CNC
    Dec 2013
    290
    Or you could just add the tap to the thread chart in bobcad.... You just need to know what the thread pitch of the tap is.
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
    Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
    Feb 2012
    8
    Thread pitch of the helicoil tap should be the same as the finished thread size.
    Quote Originally Posted by Rotax91 View Post
    Hey guys,
    Thanks.
    It's the same pitch and you can get spiral point and spiral flute taps for the inserts, provided your machine can drive the slightly larger tap I can't see why you think you have an issue?
    Feb 2017
    32
    Personally its such an easy thing to do manually why bother with a cad system to do tapping?
    Quote Originally Posted by macroguy View Post
    Well you wouldn't, you'd use a CAM system and a CNC system, in your CAD system would only need a point to define the centre and you'd define surface and depth in CAM
    Apr 2009
    3376
    Nick,,,I have manually tapped 10's of thousands of holes with tap-a-matic
    2 things
    1-you don't need to tie up a $100,000 machine
    2-it's faster
    Quote Originally Posted by jrmach View Post
    I agree with you, I was just pointing out threading with a tap isn't done in CAD
    The only threading I do on a mill it thread-milled where I need something a tap can't achieve,
    - Nick
  1. Thread forming Taps
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 06-06-2015, 03:45 PM
  2. Thread form taps.. anyone mind spoon feeding me some info?
    By compunerdy in forum Tormach Personal CNC Mill
    Last Post: 09-09-2013, 01:38 AM
  3. considerations for thread forming taps
    By 1ctoolfool in forum Haas Mills
    Last Post: 08-10-2012, 12:23 PM
  4. Special Thread Taps Huge Selection
    By CDTooling in forum News Announcements
    Last Post: 08-20-2010, 01:56 PM
  5. HeliCoil Taps
    By ranchak in forum MetalWork Discussion
    Last Post: 07-04-2009, 01:52 PM
