587,781 active members*
2,846 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > does this set up sound right?
    Jun 2004
    201
    Hi all, as you can see im a newb. I have only been working with a lathe and Im buying my first mill this week.
    Ive managed to secure a sieg x3 and im trying to work out the set up for the cnc conversion. For the time being im going to stay stock on the mill it self and upgrade to ball screws at a later time.
    But im so confused about the process of setting up a cnc system. I have a process in mind and im hoping to get expert opinions on the way to go.
    Seanet has quoted me on a servo kit which includes
    G320.G340 case
    Db25 with screw terminals
    Connector kit
    4 module heatsink
    3 G320 servo amps
    3 E540 servo motors with 250 cpr encoders
    power supply 36V 25A
    3 encoder cables
    3 motor cables
    So all I need from there is
    Motor mounts
    PC with cam software
    am i missing anything? Does it just plug into the printer port?
    Im so overwhelmed with all the information on the net, it should be simple to put together, but the info is so parted out its hard to comprehend the actual parts needed.
    Thanks Rob
    Mar 2003
    2139
    It should just hook to your parallel port, but contact Seanet to be sure. You need software to drive the motors too, such as Turbocnc $20.00 or Mach2 $150.00
    Eric
    I wish it wouldn't crash.
    Jun 2004
    201
    Very cool. Im also talking with a great guy Aaron Moss about doing a full kit with ball screws and motor mounts. He just happens to have an X3 there so hopefully he can put together something sweet.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. Rapid to (# set by Parameter) What's yours?
    By Scott_bob in forum G-Code Programing
    Last Post: 09-01-2021, 06:05 PM
  3. Add a second set of rails to X axis..need advice.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 06-01-2005, 01:11 AM
  4. Running a set number of parts?
    By Shizzlemah in forum Centroid CNC Control Products
    Last Post: 05-03-2005, 12:47 AM
  5. How to set up Tool Offset in MACH2?
    By High Seas in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2004, 06:54 PM
