603,879 active members*
4,843 visitors online*
Results 1 to 4 of 4
    Oct 2006
    79
    Don't know what I broke on IH CNC
    I was unravelling the wires from around my machine, IH CNC, and put the Y axis encoder wire on the X axis. The X ran away and hasn't worked since. The motor still spins, I swapped the geckos and it's still good, wiring and encoder seem fine. The motor won't even lock up. Powered up I can turn the axis by hand. It will make feeble, itermittant attempts to lock up and the gecko will fault out. I tweeked the gecko adjustments till I can see them with my eyes closed.
    Any help is appreciated, Shepard
    Jul 2007
    75
    Call Me
    Hi Shepard;
    Call me tomorrow night (Sunday) about 9 pm EST and we'll go over what you did and see if we can fix your problem over the phone.
    IHCNC
    Gene & Tommy
    Feb 2006
    794
    I'll venture a bet that the axis bottomed out HARD and you smoked the motor ! ! I smoked mine by going through the limit switch then absent mindedly bumping the axis the wrong direction ! ouch !
    Don
    IH v-3 early model owner
    Oct 2006
    79
    You are exactly correct. I thought the motor was still good but was wrong. I came across a nema 34 servo for a song that only needed a couple flange holes to be opened up to bolt on to our IH bracket. I'm waiting for the timing pulley to get here and should be up and running.
  1. she,s a broke eh
    By corrie in forum DNC Problems and Solutions
    Last Post: 09-12-2007, 11:08 PM
  2. r-8 locating pin broke
    By jarr88 in forum Benchtop Machines
    Last Post: 08-27-2007, 01:32 AM
  3. HL1 Counterbalance Spring Broke
    By Geof in forum Haas Lathes
    Last Post: 07-26-2007, 06:37 PM
  4. I found a Sherline set and then broke it.
    By Ubarch in forum Benchtop Machines
    Last Post: 10-29-2005, 04:27 PM
  5. Broke my Drill Press!
    By JavaDog in forum MetalWork Discussion
    Last Post: 09-02-2005, 12:31 AM
