Hello Guys
Im running a long shaft job that will get transfer to the sub. Down in the draw tube of the Sub there is the work ejection which is only 5 inch's deep. The shaft I would like to transfer needs to go 7 inch's deep into the draw tube on the Sub side.
So the question is, can the work ejection be moved back or removed from the Sub spindle draw tube easily?? Also I know that the work ejection will do its funtion with M116 (the M116 will make it cycle), can anyone tell me the M code to just make it move to the extented position. I have seen it in the extended position before.
Thanks for any of your help Guys
Mike In Canada
