587,997 active members*
1,828 visitors online*
Results 1 to 4 of 4
    Jun 2007
    68
    doosan fanuc 18t turret
    I'm having something at least strange, the turret is one position after the control, when the control is on the tool number 1 the turret is on number 2...
    is there any parameter, troubleshoot, pray or something else to help me?
    Mar 2006
    167
    If you select a tool by MDI, does it index to the correct tool?
    May 2007
    1003
    Ozemale6t9 asked a good question. What is the answer?
    I am not a maintenance man, so I asked ours about your problem. If it is indexing to the wrong station when you use MDI, then what I gather is first you index the turret so that station on is up. There should be an encoder under a cover on the side of the turret. Turn the encoder until a red light comes on. This shouold fix it.
    However, if it doesn't please don't take it out on the messenger!
    Jun 2007
    68
    I have the problem solved...
    on the mdi the turret index without problems, but with one tool behind the control..
    a guy from england gave me the parameter to chance (1805?) I had do select the tool #1 change the parameter (A) from 1 to 0, and changed back to 1, then I turned off and on again, and the machine was working fine....
    thanks for all..
  1. Turret clamp prob, Fanuc 18i
    By derwood in forum Fanuc
    Last Post: 03-27-2008, 04:57 PM
  2. fanuc 21i double turret
    By nabil_elbadri in forum Fanuc
    Last Post: 01-12-2008, 06:08 AM
  3. Fanuc 18i Turret Index limitation? (need help)
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2007, 02:14 AM
  4. Fanuc 18i - KIA SKT250MS - Turret ?
    By Joey in forum Fanuc
    Last Post: 02-27-2007, 05:23 PM
  5. HELP! need FANUC motor for my turret press
    By recycleroy in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2006, 08:19 PM
