587,195 active members*
2,842 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Puma 400 & 18i-T - don't reset work offset
Results 1 to 5 of 5
    Jun 2008
    113
    This lathe is the only machine in our shop that resets work coordinate back to G54 on reset. Annoying as hell Is there a parameter not to do so?
    Thanks much.
    Dec 2012
    395
    Re: Doosan Puma 400 & 18i-T - don't reset work offset
    Check par. 1201 #7 (WZR)
    On my 18i-TB par. 1201 #7 = 0
    #7 #6 #5 #4 #3 #2 #1 #0
    WZR -- AWK -- FPC ZCL ZPI ZPR
    par. 1201 WZR:
    Upon reset, the workpiece coordinate system is:
    0 : Not returned to that specified with G54
    1 : Returned to that specified with G54
    Regards,
    Heavy_Metal.
    Jun 2008
    113
    Thanks for the input but there is only AWK -- FPC ZCL ZPI ZPR. No WZR
    Feb 2013
    788
    Quote Originally Posted by myhäje View Post
    According to the manual for an 18i,1201.7 is correct.
    (Copied from a pdf of the Fanuc pocket manual for a 16i,18i,or 21i control)
    01201 Coordinate system
    #0 ZPR : When manual reference position return is
    performed the automatic coordinate system is
    not set (0)/set automatically (1) when a
    workpiece coordinate system option is not
    provided
    #1 ZPI : The coordinate value of automatic coordinate
    system is set PRM1250 (0)/PRM1250, 1251
    (1)
    #2 ZCL : When manual reference position return is
    performed the local coordinate system is, not
    canceled (0)/canceled (1)
    #3 FPC : When the floating reference position is set, the
    relative position display is not preset (0)/is
    preset (1)
    #5 AWK : When to change workpiece origin offset, value
    is changed from preprocessing step (0)/
    changed immediately (1)
    #7 WZR: Upon reset, the workpiece coordinate system
    is not returned (0)/returned (1) to that specified
    with G54
    (T series)
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    Try setting it...see if it fixes the issue.
  1. Buying a used doosan puma 480, puma 800l
    By Michael82 in forum Daewoo/Doosan
    Last Post: 09-05-2015, 01:44 PM
  2. Work Transfer Doosan - Puma TT 2000 SY
    By The-Chip in forum Daewoo/Doosan
    Last Post: 10-17-2014, 07:27 PM
  3. Help with doosan puma 300 lb
    By mattlynx in forum Daewoo/Doosan
    Last Post: 12-04-2013, 09:56 PM
  4. work offset page, puma 250, fanuc 18T
    By cuz1007 in forum Daewoo/Doosan
    Last Post: 03-29-2009, 06:32 PM
