603,794 active members*
4,595 visitors online*
Page 6 of 6 456
Results 101 to 114 of 114
  1. #101
    Jun 2004
    6618
    I have good luck just machining one side. I use both colors. I don't expose my machines to sunshine. That may be the biggest issue.
    Lee
  2. #102
    Feb 2010
    3450
    Quote Originally Posted by LeeWay View Post
    I suppose as long as i dont expose it to light or heat, and store it flat, it should be ok.
  3. #103
    Mar 2010
    275
    epoxy/MDF
    I've built a few fixtures out of MDF coated with System 3 boatbuiding epoxy. I let the MDF heat on an electric griddle for about 20 minutes, the heat makes it suck up the epoxy like a sponge. Then I put it back on the griddle at very low heat and the epoxy cures in about an hour and a half.
    -Jim Hart
    My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
  4. #104
    Feb 2010
    3450
    modular tooling pins?
    I'm trying to think of ways to get around drilling holes in my precious table. I want tooling pins to locate my fixtures, but dont want them permanent or to damage the table. any clues?
  5. #105
    Feb 2010
    3450
    Quote Originally Posted by Boltz View Post
    -Jim Hart
    Jim, that sounds like it could be a good way to make really inexpensive jigs with the same performance that hdpe has for a lot less money! any pics?
  6. #106
    Feb 2010
    3450
    HDPE utility grade black (blend of virgin and reprocessed HDPE).
    48"x96" sheet:
    3/8"- $102
    1/2"- $137
    3/4"- $205
    1"- $274
    Seems like the prices dropped down a bit. 3/4" use to be $250+ dollars.
    (prices from Kurbell plastics, WA state)
    3/4" would be adequate correct? I would think 1/2" would be too thin for a double sided jig. More than enough for a single sided jig however.
    I'm going to design a "fake" widget part. something that has 4-6 pieces and attempt to make a jig out of hdpe and then hopefully learn from my mistakes and refine it until i can repeat the parts over and over. Then the concept will be sound and i should be good to go on designing something that makes some $.
  7. #107
    Feb 2010
    3450
    Need help! Jig alignment to X/Y question.. im lost.
  8. #108
    Table Setup
    I haven't read the whole post but what do you intend to put on your table as a spoil board i.e 3/4 MDF. I understand you are concerned about the table base being damaged.
    How are you going to attach the 3/4 MDF removable spoil board to the table?
    Has your control been setup where you can home your machine in X,Y & Z axis?
    What software are you using to run your machine? i.e. Mach 3
    What accuracy is needed for placement of your parts and or fixtures?
    Do you have a probe and probing software?
    The reason I ask this is that I am in a similar junction with my Shopbot PRT 48 X 96 CNC Router. This is my plan and I believe it will work for my purposes.
    My current 3/4 MDF spoil board is mounted to the frame i.e. metal table with bolts recessed into the spoil board. The former owner chose to use 1/4 X 20 Nylon bolts in case a bit should hit one of them.
    I have read that someone drilled a hole pattern in the spoil board in the X and Y axis i.e. 1/4 inch holes. Then you could place removable pins in the MDF spoil board to locate your part i.e. a couple on each both the X and Y axis to square the part on the machine. Once the part is attached to the spoil board then the pins would be removed. You would know where the part is located on the table by the location of the pin hole pattern originally drilled. Then when I design a part, fixture location I first draw a rectangle which is the size of the table and draw that part at the selected location based on the drill pin hole locations drilled in the table.
    In my Mach3 2010 screen set you also have the ability to do probing options and that could also be an answer to locating parts on the X and Y axis. Not sure what software you are running.
    Just some information that may be of some help. I have enjoyed your thread.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  9. #109
    Feb 2010
    3450
    I'm minimizing waste by using a jig made of HDPE. I have specific parts to be cut so i can make sure i will be able to resue the jig over and over as long as i can zero off its corner correctly.
    The Jig is powered purely by vacuum on both sides. One side to suck to table, the other to hold down the part.
    Yes, i use mach 3 and it homes using optical sensors in the x,y, and z direction (corner of table). I would like a very high accuracy. <.010 or better. I can make my channels around the part larger then they need to be to account for mis alignment and so it wont cut into my jig. say if i use a 1/4" endmill, i may place a 1/2" trence or pocket around the outside of the part and gasket so i have some room to play.
    I will be buying a probe and touch off kit soon. Probably a starret last word, and this CNC4PC
    Thanks for the information, hopefully i can figure it out
    Quote Originally Posted by HelicopterJohn View Post
    John
  10. #110
    Feb 2010
    3450
    This friday im buying the HDPE! :P
  11. #111
    Feb 2010
    3450
    ½” x 48” x 96” UG Black HDPE - $137.08
    2 sheets ordered! Tomorrow ill pick them up!
  12. #112
    Aug 2008
    409
    Quote Originally Posted by diyengineer View Post
    1/2" is pretty thin for a jig, are you not planning on machining grooves for your gasket?
  13. #113
    Feb 2010
    3450
    Quote Originally Posted by Phife View Post
    I am, 1/4". Just doing a tester first. Going to cut it down into smaller pieces probably 12 inches by 12 inches. First time cutting stuff on it to, so lots of learning. 2 flute should work I hppe
  14. #114
    Feb 2010
    3450
    Talking
    [ame=http://www.youtube.com/watch?v=rRo-IZC-2Kw]Cnc Rebuild Video #89 - YouTube[/ame]
    Single Sided vacuum fixture. Uses 1/4-20 square nuts inset into HDPE. I can bolt the objects to the plate, or make cams that bolt down sheet for engraving, etc.
    Just a tester to see how my machine will run, as well as how the vacuum gasketing works.
    Solidworks 2010--> Cam Bam--> G code--> Cut Viewer--> Mach 3--> Solidworks photoview 360
Page 6 of 6 456
  1. Two Sided Milling Fixture
    By Mihelich in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-20-2009, 08:50 PM
  2. Gasket material for Vacuum Workholding
    By tminnig in forum MetalWork Discussion
    Last Post: 03-30-2009, 03:04 PM
  3. double sided hold down
    By ronateah in forum WoodWorking Topics
    Last Post: 11-07-2007, 01:30 AM
  4. Double sided tape
    By Greolt in forum CNC Tooling
    Last Post: 09-17-2007, 10:11 PM
  5. double sided job setups
    By july_favre in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2004, 04:27 PM
