I recently started work at a shop that uses EdgeCAM and it seems quite limited in the range of possible tool definitions.
Does anyone out there have dovetails defined? I need to mill a negative 5 degree taper and in the past I would have defined a dovetail tool, defined the surface, then let the CAM calculate the path.
Can edgecam do this or will I need to use a custom tool with the required taper?
Any assistance is appreciated.
