587,613 active members*
3,450 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Dowel Pin Hole Preparation
Hybrid View
    Jul 2010
    174
    Hello,
    Havn't used dowel pins a whole lot and was wondering...
    I want to prep a hole for a 5/8" dowel pin. Its going in steel. Whats a recommended drill size? Should I use a reamer? What reamer size?
    I've heard that dowel pins are a standard +.0002" oversize. Is that true?
    Sort of in the same way a gauge pin minus set is standardly -.0002" undersize and a gauge pin plus set is standardly +.0002" oversize.
    Thanks.
    Sep 2004
    149
    This might be helpful for dowel pin sizes:
    McMaster-Carr
    You can buy reamers from L&i that are made for any size you want- press fit or clearance fit. They list some of their reamers as made for press fit and give the sizes- I think on their web site.
    Lavallee & Ide - The Reamer Specialists
    catalog:
    http://www.lavallee-ide.com/files/catalog2011.pdf
    For drilling prior to reaming, I've been making the holes .008 under the size of the reamer, but I've found that .004 under works too.
    Jul 2010
    174
    Thanks very much.
    I downloaded everything and am taking a look at it.
  1. New Sieg C3 Out of the Box Preparation.
    By microid in forum Mini Lathe
    Last Post: 12-24-2010, 06:48 PM
  2. Dowel Pin Hole Preparation
    By pearldiver in forum MetalWork Discussion
    Last Post: 12-29-2009, 06:28 PM
  3. Rotary table clean up and preparation
    By chola in forum MetalWork Discussion
    Last Post: 02-20-2007, 09:48 PM
  4. Power supply/preparation unit
    By atifeh in forum CNC Machine Related Electronics
    Last Post: 07-17-2006, 05:32 PM
  5. Part preparation for CNC milling
    By CarbonMike in forum PTC Pro/Manufacture
    Last Post: 04-14-2006, 01:07 PM
