hey guys! i need some advice about a DIY milling machine i want to build out of a benchtop drill press.
i have a benchtop drill press that can go from a minimum of 580 RPM to a maximum of 2650 RPM with a couple of stages in between.
my plan is to buy an x-y table and use the drill press as a milling machine and convert it to cnc.
i know that the smaller the router bit diameter, the higher the RPM needed to cut properly, so my question is, is 2650 RPM enough to mill, say aluminium with a 3mm router bit? if not, what's the best i can do? (ie use a bigger diameter router bit or softer materials)
i dont mind slow feedrates
thanks!
